ve.direct:ve.direct_to_bluetooth_smart_dongle [2018-01-07 23:35] – [Manual - VE.Direct to Bluetooth Smart dongle] justin_tyers_live_a_c | ve.direct:ve.direct_to_bluetooth_smart_dongle [2019-01-22 10:16] – external edit 127.0.0.1 | ||
====== Manual - VE.Direct to Bluetooth Smart dongle ====== | ====== Manual - VE.Direct to Bluetooth Smart dongle ====== | ||
- | **Note: this product was previously called the VE.Direct to Bluetooth LE dongle**. There are no differences, | ||
Product page on our main website:\\ | Product page on our main website:\\ | ||
Line 12: | Line 10: | ||
With the VE.Direct to Bluetooth Smart dongle you can get live status info, see historical values as well as configure Victron products.\\ | With the VE.Direct to Bluetooth Smart dongle you can get live status info, see historical values as well as configure Victron products.\\ | ||
+ | Note: this product was previously called the **VE.Direct to Bluetooth LE dongle**. There are no differences, | ||
==== Compatible Victron products ==== | ==== Compatible Victron products ==== | ||
Line 49: | Line 49: | ||
| Slow blinking | | Slow blinking | ||
| On | Off | VE.Direct gateway | Connected | | On | Off | VE.Direct gateway | Connected | ||
- | | Double flash | Double flash | VE.Direct gateway | Clearing pin | | + | | Double flash | Double flash | VE.Direct gateway | Not connected |
- | | Fast blinking | + | |
Line 72: | Line 71: | ||
* Try to disconnect the dongle and reconnect to the same product. | * Try to disconnect the dongle and reconnect to the same product. | ||
* Try to connect the dongle to a different product when available. | * Try to connect the dongle to a different product when available. | ||
- | * Check if VictronConnect can see the device when using a VE.Direct cable connected to a PC or android phone | + | * Check if VictronConnect can see the device when using a VE.Direct |
See the [[https:// | See the [[https:// | ||
Line 97: | Line 96: | ||
The length of the VE.Direct cable is 1.5m | The length of the VE.Direct cable is 1.5m | ||
