ve.direct:mpptprefs
ve.direct:mpptprefs [2017-09-05 20:48] – [THIS PAGE IS DEPRECATED: Use VictronConnect instead of mpptprefs] mvaderve.direct:mpptprefs [2019-01-22 10:16] (current) – external edit 127.0.0.1
Line 29: Line 29:
 ===== Instructions ===== ===== Instructions =====
-  * Download mpptprefs.exe here: [[https://www.victronenergy.com/support-and-downloads/software#mpptprefs|https://www.victronenergy.com/support-and-downloads/software#mpptprefs]]
   * In case the VE.Direct to USB cable is not recognized on your system you may need to download the driver from the [[https://www.victronenergy.com/support-and-downloads/software#ve-power-setup|VE Power Setup section on our Software page]].   * In case the VE.Direct to USB cable is not recognized on your system you may need to download the driver from the [[https://www.victronenergy.com/support-and-downloads/software#ve-power-setup|VE Power Setup section on our Software page]].
Line 332: Line 331:
 The above sequential commands, resets the charger to factory default settings and clears the history data. The above sequential commands, resets the charger to factory default settings and clears the history data.
 +===== DISQUS =====
 ~~DISQUS~~ ~~DISQUS~~
ve.direct/mpptprefs.1504637308.txt.gz · Last modified: 2017-09-05 20:48 by mvader
