ve.direct:mpptprefs
ve.direct:mpptprefs [2017-08-09 00:10] – [DEPRECATED: Use VictronConnect instead of mpptprefs] guystewartve.direct:mpptprefs [2019-01-22 09:16] (current) – external edit 127.0.0.1
Line 4: Line 4:
 ===== THIS PAGE IS DEPRECATED: Use VictronConnect instead of mpptprefs ===== ===== THIS PAGE IS DEPRECATED: Use VictronConnect instead of mpptprefs =====
-We recommend to use [[victronconnect:start|VictronConnect]] instead of mpptprefs. Much simpler and faster to use. Also it includes automatic firmware updates. More information in the [[victronconnect:start|VictronConnect manual]].+We recommend to use [[victronconnect:start|VictronConnect]] instead of mpptprefs. Much simpler and faster to use. Also it includes automatic firmware updates.
 +More information: [[victronconnect:mppt-solarchargers|]]
Line 27: Line 29:
 ===== Instructions ===== ===== Instructions =====
-  * Download mpptprefs.exe here: [[https://www.victronenergy.com/support-and-downloads/software#mpptprefs|https://www.victronenergy.com/support-and-downloads/software#mpptprefs]]
   * In case the VE.Direct to USB cable is not recognized on your system you may need to download the driver from the [[https://www.victronenergy.com/support-and-downloads/software#ve-power-setup|VE Power Setup section on our Software page]].   * In case the VE.Direct to USB cable is not recognized on your system you may need to download the driver from the [[https://www.victronenergy.com/support-and-downloads/software#ve-power-setup|VE Power Setup section on our Software page]].
Line 330: Line 331:
 The above sequential commands, resets the charger to factory default settings and clears the history data. The above sequential commands, resets the charger to factory default settings and clears the history data.
 +===== DISQUS =====
 ~~DISQUS~~ ~~DISQUS~~
ve.direct/mpptprefs.1502237441.txt.gz · Last modified: by guystewart
