ve.direct:mpptprefs
ve.direct:mpptprefs [2016-04-22 13:03] – [Batch mode] d.t.schneiderleinve.direct:mpptprefs [2019-01-22 09:16] (current) – external edit 127.0.0.1
 ====== Changing settings in the BlueSolar MPPT Charge Controllers ====== ====== Changing settings in the BlueSolar MPPT Charge Controllers ======
-===== Applicable products =====+
 +===== THIS PAGE IS DEPRECATED: Use VictronConnect instead of mpptprefs =====
 +We recommend to use [[victronconnect:start|VictronConnect]] instead of mpptprefs. Much simpler and faster to use. Also it includes automatic firmware updates.
 +More information: [[victronconnect:mppt-solarchargers|]]
 +===== Original text =====
 +Products:
   * BlueSolar Charge controller MPPT 70/15 (replaced with the 75/15)   * BlueSolar Charge controller MPPT 70/15 (replaced with the 75/15)
Line 18: Line 29:
 ===== Instructions ===== ===== Instructions =====
-  * Download mpptprefs.exe here: [[https://www.victronenergy.com/support-and-downloads/software#mpptprefs|https://www.victronenergy.com/support-and-downloads/software#mpptprefs]]
   * In case the VE.Direct to USB cable is not recognized on your system you may need to download the driver from the [[https://www.victronenergy.com/support-and-downloads/software#ve-power-setup|VE Power Setup section on our Software page]].   * In case the VE.Direct to USB cable is not recognized on your system you may need to download the driver from the [[https://www.victronenergy.com/support-and-downloads/software#ve-power-setup|VE Power Setup section on our Software page]].
Line 120: Line 130:
 Change the load switch on/off behavior. By default the battery life algorithm will be used (option 1). Normally a jumper can be used to select between two fixed switch on/off set-points. However if you require communication with the charger (e.g. when connecting a Color Control) you can use options 2 or 3 to preset a conventional algorithm. Options 5 and 6 can be used to create custom algorithms, with programmable switch on and switch off levels (see options 'h' and 'l'). Change the load switch on/off behavior. By default the battery life algorithm will be used (option 1). Normally a jumper can be used to select between two fixed switch on/off set-points. However if you require communication with the charger (e.g. when connecting a Color Control) you can use options 2 or 3 to preset a conventional algorithm. Options 5 and 6 can be used to create custom algorithms, with programmable switch on and switch off levels (see options 'h' and 'l').
 +Keep in mind that modes 0 (always off) and 4 (always on) will respond immediately, the other modes rely on the battery voltage and have a delay of 2 minutes before the load output will change (so the charger does not respond too quickly when for example an inrush current briefly lowers the battery below the threshold voltage).
 {{  :ve.direct:721f3e879afdb7ed21d8eec069a3a628.png  }} {{  :ve.direct:721f3e879afdb7ed21d8eec069a3a628.png  }}
Line 319: Line 331:
 The above sequential commands, resets the charger to factory default settings and clears the history data. The above sequential commands, resets the charger to factory default settings and clears the history data.
 +===== DISQUS =====
 ~~DISQUS~~ ~~DISQUS~~
ve.direct/mpptprefs.1461330197.txt.gz · Last modified: by d.t.schneiderlein
