ve.direct:mpptprefs
| ve.direct:mpptprefs [2015-09-07 14:09] – [Instructions] rvanzundert | ve.direct:mpptprefs [2019-01-22 09:16] (current) – external edit 127.0.0.1 | ||
| Line 1: | Line 1: | ||
| ====== Changing settings in the BlueSolar MPPT Charge Controllers ====== | ====== Changing settings in the BlueSolar MPPT Charge Controllers ====== | ||
| - | ===== Applicable products | + | |
| + | ===== THIS PAGE IS DEPRECATED: Use VictronConnect instead of mpptprefs | ||
| + | We recommend to use [[victronconnect: | ||
| + | More information: | ||
| + | ===== Original text ===== | ||
| + | Products: | ||
| * BlueSolar Charge controller MPPT 70/15 (replaced with the 75/15) | * BlueSolar Charge controller MPPT 70/15 (replaced with the 75/15) | ||
| Line 11: | Line 22: | ||
| * BlueSolar Charge controller MPPT 100/50 | * BlueSolar Charge controller MPPT 100/50 | ||
| * BlueSolar Charge controller MPPT 150/35 | * BlueSolar Charge controller MPPT 150/35 | ||
| + | * BlueSolar Charge controller MPPT 150/60 (Tr/MC-4) | ||
| + | * BlueSolar Charge controller MPPT 150/70 (Tr/MC-4) | ||
| + | * BlueSolar Charge controller MPPT 150/85 (Tr/MC-4) | ||
| + | * BlueSolar Charge controller MPPT 150/100 (Tr/MC-4) | ||
| ===== Instructions ===== | ===== Instructions ===== | ||
| - | | + | * In case the VE.Direct to USB cable is not recognized on your system you may need to download the driver from the [[https:// |
| ===== VE.Direct connection ===== | ===== VE.Direct connection ===== | ||
| Line 79: | Line 93: | ||
| Available from firmware 1.16 and higher. | Available from firmware 1.16 and higher. | ||
| + | **k** - Modify temperature compensation | ||
| + | Set-up temperature compensation. Allowed range -21mV/K .. 21mV/K, use value 0 to disable the temperature compensation (e.g. for Lithium batteries). | ||
| + | Please note that the temperature compensation is not dynamic during operation. The charger uses its internal temperature for the battery temperature compensation when the charger has been idle for at least one hour, i.e. when the charger is not actively charging a battery or supplying a load. | ||
| + | **m** - Modify absorption time limit | ||
| + | Set-up the absorption time limit. Enter the time value in the notation hh:mm, where hh=hours (0..12), mm=minutes (00..59). | ||
| + | The maximum duration of the absorption period is determined by the battery voltage measured just before the solar charger starts up in the morning: | ||
| + | ^Battery voltage Vb (@start-up) ^ Multiplier ^ Maximum absorption times ^ | ||
| + | | Vb < 11.9V | ||
| + | | 11.9V < Vb < 12.2V | ||
| + | | 12.2V < Vb < 12.6V | ||
| + | | Vb > 12.6V | ||
| **t** - Switch back to the factory defined battery table / rotary switch position \\ Modifying any of the charge parameters (a, b, f and c) automatically creates a user defined battery type. Use this option to switch back to the factory defined algorithm. | **t** - Switch back to the factory defined battery table / rotary switch position \\ Modifying any of the charge parameters (a, b, f and c) automatically creates a user defined battery type. Use this option to switch back to the factory defined algorithm. | ||
| Line 99: | Line 130: | ||
| Change the load switch on/off behavior. By default the battery life algorithm will be used (option 1). Normally a jumper can be used to select between two fixed switch on/off set-points. However if you require communication with the charger (e.g. when connecting a Color Control) you can use options 2 or 3 to preset a conventional algorithm. Options 5 and 6 can be used to create custom algorithms, with programmable switch on and switch off levels (see options ' | Change the load switch on/off behavior. By default the battery life algorithm will be used (option 1). Normally a jumper can be used to select between two fixed switch on/off set-points. However if you require communication with the charger (e.g. when connecting a Color Control) you can use options 2 or 3 to preset a conventional algorithm. Options 5 and 6 can be used to create custom algorithms, with programmable switch on and switch off levels (see options ' | ||
| + | Keep in mind that modes 0 (always off) and 4 (always on) will respond immediately, | ||
| Line 166: | Line 199: | ||
| Erase the historical data (daily logs and statistics). This data is available on the ve.direct output. A Color Control can be used to view this data. | Erase the historical data (daily logs and statistics). This data is available on the ve.direct output. A Color Control can be used to view this data. | ||
| - | **f** - VE.Direct TX Port function | + | **p** - VE.Direct TX Port function |
| The function of the TX pin on the VE.Direct connector can be used for other functions. Available options: | The function of the TX pin on the VE.Direct connector can be used for other functions. Available options: | ||
| Line 177: | Line 210: | ||
| **3** - In combination with the lighting controller (solar timer), the light can be dimmed using an inverted PWM signal from the TX port. | **3** - In combination with the lighting controller (solar timer), the light can be dimmed using an inverted PWM signal from the TX port. | ||
| + | **4** - Virtual load output. This enables the Streetlight functionality on the larger MPPT models. The load output can be realized via the VE.Direct connector by using cable ASS030550500. Connect the cable to a battery protect module or a solid state relay. | ||
| Notes: the PWM output (when using options 2 and 3) operates at a fixed frequency of 160Hz and has a fixed voltage level of 5V. | Notes: the PWM output (when using options 2 and 3) operates at a fixed frequency of 160Hz and has a fixed voltage level of 5V. | ||
| - | {{ :ve.direct:67329505be78626e25550df988383cb2.png }} | + | {{ :ve.direct:mpptprefs_tx_port.png |
| + | **q** - VE.Direct RX Port function | ||
| + | The function of the RX pin on the VE.Direct connector can be used for other functions. This functionality is introduced in firmware version 1.17 and applies to the 10A and 15A chargers with a load output. | ||
| + | Available options: | ||
| + | **0** - Remote on/off. Allows remote charger on/off control (0V = switch charger off, +5V or VE.Direct communication = switch charger on), e.g. to connect to a VE.BUS BMS (using cable ASS030550300). | ||
| + | **1** - Load output configuration (default behavior). | ||
| + | **2** - Load output on/off. Allows remote control of the load output (0V = switch load on, +5V or VE.Direct communication = switch load off). | ||
| ===== Batch mode ===== | ===== Batch mode ===== | ||
| Line 214: | Line 262: | ||
| - | VE.Direct mpptprefs 1.12 | + | VE.Direct mpptprefs 1.15 |
| Allowed options: | Allowed options: | ||
| -d [ --dump ] dump communication to output | -d [ --dump ] dump communication to output | ||
| Line 227: | Line 275: | ||
| -i [ --eqv ] arg set equalisation voltage | -i [ --eqv ] arg set equalisation voltage | ||
| -j [ --autoeq ] arg set auto equalise mode | -j [ --autoeq ] arg set auto equalise mode | ||
| + | -k [ --tempcomp ] arg set temperature compensation | ||
| + | -m [ --abslim ] arg set absorption time limit | ||
| -t [ --table ] use factory defined battery table | -t [ --table ] use factory defined battery table | ||
| -r [ --reset ] reset all settings to factory default settings | -r [ --reset ] reset all settings to factory default settings | ||
| Line 237: | Line 287: | ||
| - | Note that commands -a, -f, -b, -c, -i and -j can be combined to change multiple settings at once: | + | Note that commands -a, -f, -b, -c, -i, -j, -k and -m can be combined to change multiple settings at once: |
| Line 281: | Line 331: | ||
| The above sequential commands, resets the charger to factory default settings and clears the history data. | The above sequential commands, resets the charger to factory default settings and clears the history data. | ||
| + | ===== DISQUS ===== | ||
| ~~DISQUS~~ | ~~DISQUS~~ | ||
ve.direct/mpptprefs.1441634981.txt.gz · Last modified: by rvanzundert
