ve.direct:mpptprefs
ve.direct:mpptprefs [2016-09-07 16:08] – rvanzundert | ve.direct:mpptprefs [2019-01-21 11:13] – [Batch mode] ictbeheer | ||
Line 2: | Line 2: | ||
- | ===== DEPRECATED: Use VictronConnect instead of mpptprefs ===== | + | ===== THIS PAGE IS DEPRECATED: Use VictronConnect instead of mpptprefs ===== |
- | We recommend to use VictronConnect instead of mpptprefs. Much simpler and faster to use. Also it includes automatic firmware updates. More information | + | We recommend to use [[victronconnect: |
+ | More information: [[victronconnect: | ||
Line 27: | Line 29: | ||
===== Instructions ===== | ===== Instructions ===== | ||
- | * Download mpptprefs.exe here: [[https:// | ||
* In case the VE.Direct to USB cable is not recognized on your system you may need to download the driver from the [[https:// | * In case the VE.Direct to USB cable is not recognized on your system you may need to download the driver from the [[https:// | ||
Line 330: | Line 331: | ||
- | ~~DISQUS~~ | ||
