ve.direct:mpptprefs
ve.direct:mpptprefs [2016-06-14 23:12] – [Original text] mvader | ve.direct:mpptprefs [2019-01-22 10:16] (current) – external edit 127.0.0.1 | ||
Line 2: | Line 2: | ||
- | ===== DEPRECATED: Use VictronConnect instead of mpptprefs ===== | + | ===== THIS PAGE IS DEPRECATED: Use VictronConnect instead of mpptprefs ===== |
- | We recommend to use VictronConnect instead of mpptprefs. Much simpler and faster to use. Also it includes automatic firmware updates. More information | + | We recommend to use [[victronconnect: |
+ | More information: [[victronconnect: | ||
Line 27: | Line 29: | ||
===== Instructions ===== | ===== Instructions ===== | ||
- | * Download mpptprefs.exe here: [[https:// | ||
* In case the VE.Direct to USB cable is not recognized on your system you may need to download the driver from the [[https:// | * In case the VE.Direct to USB cable is not recognized on your system you may need to download the driver from the [[https:// | ||
Line 129: | Line 130: | ||
Change the load switch on/off behavior. By default the battery life algorithm will be used (option 1). Normally a jumper can be used to select between two fixed switch on/off set-points. However if you require communication with the charger (e.g. when connecting a Color Control) you can use options 2 or 3 to preset a conventional algorithm. Options 5 and 6 can be used to create custom algorithms, with programmable switch on and switch off levels (see options ' | Change the load switch on/off behavior. By default the battery life algorithm will be used (option 1). Normally a jumper can be used to select between two fixed switch on/off set-points. However if you require communication with the charger (e.g. when connecting a Color Control) you can use options 2 or 3 to preset a conventional algorithm. Options 5 and 6 can be used to create custom algorithms, with programmable switch on and switch off levels (see options ' | ||
+ | Keep in mind that modes 0 (always off) and 4 (always on) will respond immediately, | ||
Line 328: | Line 331: | ||
