ve.can:ve.can_resistive_tank_sender_adapter
ve.can:ve.can_resistive_tank_sender_adapter [2016-05-18 09:51] – [2.5 Tank sender] mvaderve.can:ve.can_resistive_tank_sender_adapter [2022-01-27 09:34] (current) – [Volume unit] mvader
Line 8: Line 8:
   * High ±1% Accuracy   * High ±1% Accuracy
   * Suits European standard 0-180 and US standard 240-30 Ohm Senders   * Suits European standard 0-180 and US standard 240-30 Ohm Senders
-  * Fuel, Freshwater, Wastewater, Oil, Live Well or Blackwater: easily selectable with a rotary switch +  * Fuel, Freshwater, Wastewater, Oil, Live Well or Blackwater: tank type easily selectable with a rotary switch
-  * Up to 16 tanks of each type. Needs one sender per tank, tank number is easily selectable with a rotaray switch+  * For multiple tanks, use multiple tank sender adapters in one network: up to 16 tanks of the same tank type
   * Robust ABS Construction sealed to IP67   * Robust ABS Construction sealed to IP67
   * Easy to install   * Easy to install
Line 15: Line 15:
   * Under 50mA Power Usage   * Under 50mA Power Usage
   * Input voltage 9 to 70 VDC   * Input voltage 9 to 70 VDC
 +For multiple tanks, use multiple tank sender adapters. Each wired to their own tank. Connect up to 16 tanks of the same type in one VE.Can network. Set each tank sender adapter to its own unique tank number with the rotary switch.
 More information on the [[https://www.victronenergy.com/accessories/ve-can-resistive-tank-sender-adapter|product page on our website]]. More information on the [[https://www.victronenergy.com/accessories/ve-can-resistive-tank-sender-adapter|product page on our website]].
Line 85: Line 87:
 {{:ve.can:tanksensor_unit.png?direct&480|}} {{:ve.can:tanksensor_unit.png?direct&480|}}
-===== DISQUS ===== +
-~~DISQUS~~+
 +===== Frequently asked questions =====
 +=== Q1: Can I configure a custom name? ===
 +No. The VE.Can Tank Sender Adapter does not accept configuring a custom name. The method available to distinguish from one tank to another are the instances.
 +This is unlike the GX Tank 140 and as well as inputs available directly on the Cerbo GX: there it is possible to configure a name.
 +=== Q2: Why is this tank sender adapter so expensive? ===
 +That is because its expensive to produce. For lower cost options, consider a GX Device with direct tank inputs, such as the Cerbo GX. And to extend those, consider our GX Tank 140. Note that the GX Tank 140 takes 0-10V and 4-20mA senders, not resistive.
ve.can/ve.can_resistive_tank_sender_adapter.1463557889.txt.gz · Last modified: 2016-05-18 09:51 by mvader
