ve.can:ve.can_resistive_tank_sender_adapter
ve.can:ve.can_resistive_tank_sender_adapter [2016-05-18 09:51] – [2.5 Tank sender] mvader | ve.can:ve.can_resistive_tank_sender_adapter [2016-06-01 09:37] – [1. Introduction] mvader | ||
Line 8: | Line 8: | ||
* High ±1% Accuracy | * High ±1% Accuracy | ||
* Suits European standard 0-180 and US standard 240-30 Ohm Senders | * Suits European standard 0-180 and US standard 240-30 Ohm Senders | ||
- | * Fuel, Freshwater, Wastewater, Oil, Live Well or Blackwater: easily selectable with a rotary switch | + | * Fuel, Freshwater, Wastewater, Oil, Live Well or Blackwater: |
- | * Up to 16 tanks of each type. Needs one sender per tank, tank number is easily selectable with a rotaray switch | + | * For multiple tanks, use multiple tank sender adapters in one network: up to 16 tanks of the same tank type |
* Robust ABS Construction sealed to IP67 | * Robust ABS Construction sealed to IP67 | ||
* Easy to install | * Easy to install | ||
Line 15: | Line 15: | ||
* Under 50mA Power Usage | * Under 50mA Power Usage | ||
* Input voltage 9 to 70 VDC | * Input voltage 9 to 70 VDC | ||
+ | For multiple tanks, use multiple tank sender adapters. Each wired to their own tank. Connect up to 16 tanks of the same type in one VE.Can network. Set each tank sender adapter to its own unique tank number with the rotary switch. | ||
More information on the [[https:// | More information on the [[https:// |
ve.can/ve.can_resistive_tank_sender_adapter.txt · Last modified: 2022-01-27 09:34 by mvader
