| ve.can:ve.bus_to_ve.can_interface_manual [2016-11-07 21:50] – [No longer required !] mvader | ve.can:ve.bus_to_ve.can_interface_manual [2020-01-06 22:05] (current) – [VE.Bus to VE.Can interface manual] mvader | ||
| Line 5: | Line 5: | ||
| Note that for brevity, Multis and Quattros are called VE.Bus devices in this manual. | Note that for brevity, Multis and Quattros are called VE.Bus devices in this manual. | ||
| - | [[https:// | + | ===== This product is deprecated, and no longer required! ===== |
| - | ===== This product is no longer required ! ===== | + | |
| This interface was, only!, used in Hub-1 systems **with grid-feedback enabled**. It interfaced between the VE.Bus system and one or more MPPT solar chargers with a VE.Can connection: the [[https:// | This interface was, only!, used in Hub-1 systems **with grid-feedback enabled**. It interfaced between the VE.Bus system and one or more MPPT solar chargers with a VE.Can connection: the [[https:// | ||
| Line 38: | Line 36: | ||
| ===== More information ===== | ===== More information ===== | ||
| * [[https:// | * [[https:// | ||
| ===== DISQUS ===== | ===== DISQUS ===== | ||
| ~~DISQUS~~ | ~~DISQUS~~ | ||
ve.can/ve.bus_to_ve.can_interface_manual.1478555449.txt.gz · Last modified: by mvader
