ve.can:ve.bus_to_ve.can_interface_manual [2016-11-07 22:50] – [No longer required !] mvader | ve.can:ve.bus_to_ve.can_interface_manual [2020-01-06 23:05] (current) – [VE.Bus to VE.Can interface manual] mvader | ||
Line 5: | Line 5: | ||
Note that for brevity, Multis and Quattros are called VE.Bus devices in this manual. | Note that for brevity, Multis and Quattros are called VE.Bus devices in this manual. | ||
- | [[https:// | + | ===== This product is deprecated, and no longer required! ===== |
- | ===== This product is no longer required ! ===== | + | |
This interface was, only!, used in Hub-1 systems **with grid-feedback enabled**. It interfaced between the VE.Bus system and one or more MPPT solar chargers with a VE.Can connection: the [[https:// | This interface was, only!, used in Hub-1 systems **with grid-feedback enabled**. It interfaced between the VE.Bus system and one or more MPPT solar chargers with a VE.Can connection: the [[https:// | ||
Line 38: | Line 36: | ||
===== More information ===== | ===== More information ===== | ||
ve.can/ve.bus_to_ve.can_interface_manual.txt · Last modified: 2020-01-06 23:05 by mvader
