ve.can:ve.bus_to_ve.can_interface_manual [2016-11-07 17:11] – mvader | ve.can:ve.bus_to_ve.can_interface_manual [2016-11-07 22:50] – [No longer required !] mvader | ||
Line 7: | Line 7: | ||
[[https:// | [[https:// | ||
- | ===== No longer required ! ===== | + | ===== This product is no longer required ! ===== |
This interface was, only!, used in Hub-1 systems **with grid-feedback enabled**. It interfaced between the VE.Bus system and one or more MPPT solar chargers with a VE.Can connection: the [[https:// | This interface was, only!, used in Hub-1 systems **with grid-feedback enabled**. It interfaced between the VE.Bus system and one or more MPPT solar chargers with a VE.Can connection: the [[https:// | ||
ve.can/ve.bus_to_ve.can_interface_manual.txt · Last modified: 2020-01-06 23:05 by mvader
