ve.can:ve.bus_to_ve.can_interface_manual [2016-01-08 16:55] – ictbeheer | ve.can:ve.bus_to_ve.can_interface_manual [2019-01-21 11:12] – [DISQUS] ictbeheer | ||
Line 7: | Line 7: | ||
[[https:// | [[https:// | ||
+ | ===== This product is no longer required ! ===== | ||
+ | This interface was, only!, used in Hub-1 systems **with grid-feedback enabled**. It interfaced between the VE.Bus system and one or more MPPT solar chargers with a VE.Can connection: the [[https:// | ||
+ | But, since the release of CCGX v1.73, it is no longer necessary. | ||
- | ===== Intended usage ===== | + | ==== Old information |
- | This interface is, only, used in Hub-1 systems **with grid-feedback enabled**. It interfaces between the VE.Bus system and one or more MPPT solar chargers with a VE.Can connection: the [[https:// | + | |
Normally these solar chargers will reduce their output power as soon as the battery voltages hits the absorption voltage. When the goal is to feedback excess power to the grid, the solar charger should continue to operate on the Maximum Power Point instead. By using this interface **together with the Hub-1 Assistant**, | Normally these solar chargers will reduce their output power as soon as the battery voltages hits the absorption voltage. When the goal is to feedback excess power to the grid, the solar charger should continue to operate on the Maximum Power Point instead. By using this interface **together with the Hub-1 Assistant**, | ||
Line 38: | Line 39: | ||
ve.can/ve.bus_to_ve.can_interface_manual.txt · Last modified: 2020-01-06 23:05 by mvader
