ve.can:updating_firmware
Updating firmware of a VE.Can product
Products which can be updated via its VE.Can port are:
- BlueSolar Charger 150/70 VE.Can
- BlueSolar Charger 150/85 VE.Can
- Lynx Shunt VE.Can
- All four Skylla-i Battery Chargers
- Skylla-i Remote Control Panel
- All our different VE.Can to VE.Bus/VE.Direct and NMEA2000 to VE.Bus/VE.Direct interfaces
- Ion Control
Products with a VE.Can port that need to be updated differently are:
- Lynx Ion (update via USB port instead)
- Lynx Ion + Shunt (update via USB port instead)
- VE.Can tank sender adapter (no updates available)
- Color Control GX (update via internet or with an sdcard)
Instructions
There are two ways to update the firmware via the VE.Can port:
- Product connected locally to the laptop. Requires the CANUSB adapter, ASS030532000.
- Product connect remotely, to a Color Control GX: Remote firmware update instructions
That last option is often the easiest way, as there is no other use to the CANUSB and it is quite expensive.
Steps:
- Download VE Power Setup from our download page, and install it
- Obtain the necessary firmware file on https://professional.victonenergy.com|the Victron Professional portal]].
- Follow instructions in VE Power Setup.
- When having issues, make sure to check the information behind the
Need help connecting?button in the application, as well as the information in the Remote firmware update instructions.
ve.can/updating_firmware.1493185015.txt.gz · Last modified: by mvader
Add this page to your book
Manage book (
Help
