ve.can:updating_firmware
ve.can:updating_firmware [2017-04-26 07:36] – [Instructions] mvader | ve.can:updating_firmware [2018-11-13 23:10] – mvader | ||
- | Products which can be updated via its VE.Can port are: | + | This page explains the procedure to update firmware for products that have a VE.Can port. There are two ways: |
- | * BlueSolar Charger 150/70 VE.Can | + | |
- | * BlueSolar Charger 150/85 VE.Can | + | |
- | * Lynx Shunt VE.Can | + | |
- | * All four Skylla-i Battery Chargers | + | |
- | * Skylla-i Remote Control Panel | + | |
- | * All our different VE.Can to VE.Bus/ | + | |
- | * Ion Control | + | |
- | Products with a VE.Can port that need to be updated differently are: | + | - Remotely via internet - applies to systems that have a Venus-device, |
- | * Lynx Ion (update via USB port instead) | + | |
- | * Lynx Ion + Shunt (update via USB port instead) | + | |
- | * VE.Can tank sender adapter (no updates available) | + | |
- | ===== Instructions ===== | + | Updating the firmware of a VE.Can product is typically most convenient by using the remote option. Its then not necessary to obtain the CANUSB adapter. In case you do need, but don't have the CANUSB, contact your dealer; they' |
- | There are two ways to update the firmware via the VE.Can port: | + | ===== Method 1: Remotely via internet ===== |
- | - Product connected locally to the laptop. Requires the CANUSB adapter, ASS030532000. | + | See [[vrm_portal:remote-firmware-update|]]. |
- | - Product connect remotely, to a Color Control GX: [[ccgx:ccgx_ve_power_setup# | + | |
- | That last option is often the easiest way, as there is no other use to the CANUSB | + | ===== Method 2: Locally, using the CANUSB |
- | Steps: | + | See [[ccgx:ccgx_ve_power_setup|]]. |
- | - Download VE Power Setup from our download page, and install it | ||
- | - Obtain the necessary firmware file on [[https:// | ||
- | - Follow instructions in VE Power Setup. | ||
- | - When having issues, make sure to check the information behind the '' |
ve.can/updating_firmware.txt · Last modified: 2019-08-15 12:52 by guy_stewart
