ve.bus:ve.bus_error_codes
ve.bus:ve.bus_error_codes [2024-02-05 07:37] – mvader | ve.bus:ve.bus_error_codes [2024-04-24 00:32] (current) – [Error 26 - Internal error] mleeftink | ||
Line 405: | Line 405: | ||
__Recovery: | __Recovery: | ||
+ | ==== Error 30 and 31 - Ghost errors ==== | ||
+ | Both these are non-listed VE.Bus errors. They are caused by a corrupted message on the VE.Bus. | ||
+ | There may be an issue with the RJ45 UTP cable(s) or their connections. | ||
+ | To try to resolve it, make the changes suggested in the “Troubleshooting VE.Bus Network interference” guide. | ||
==== Error 128 - Connect prevented by failing relay test ==== | ==== Error 128 - Connect prevented by failing relay test ==== |
ve.bus/ve.bus_error_codes.1707115038.txt.gz · Last modified: 2024-02-05 07:37 by mvader
