ve.bus:ve.bus_error_codes
ve.bus:ve.bus_error_codes [2021-10-27 11:54] – [Error 15 - VE.Bus combination error] mvader | ve.bus:ve.bus_error_codes [2022-04-29 11:29] (current) – [Error 8 - Ground relay test failed] marmour | ||
Line 9: | Line 9: | ||
- | *WARNING*: The steps and instructions explained here, are intended to be carried to be carried out by trained professionals. AC (and also DC) Voltages can be lethal. And certain settings and firmware updates require experience and training as well. | + | **WARNING**: The steps and instructions explained here, are intended to be carried to be carried out by trained professionals. AC (and also DC) Voltages can be lethal. And certain settings and firmware updates require experience and training as well. |
==== Network cable quality ==== | ==== Network cable quality ==== | ||
Line 29: | Line 29: | ||
Note for split- and three-phase systems: VRM, nor the GX device, will indicate on which phase the overload or the temperature alarm occured. To find out on which unit the error occurs, go to system after it has switched off. And look on the LEDs. The unit with the overload or temperature alarm, will have the corresponding alarm LED lit continuously. The other units will indicate a VE.Bus error, indicating that they miss one unit. | Note for split- and three-phase systems: VRM, nor the GX device, will indicate on which phase the overload or the temperature alarm occured. To find out on which unit the error occurs, go to system after it has switched off. And look on the LEDs. The unit with the overload or temperature alarm, will have the corresponding alarm LED lit continuously. The other units will indicate a VE.Bus error, indicating that they miss one unit. | ||
+ | __Recovery: | ||
==== Error 2 - New and old type MK2 protocol mixed in the system ==== | ==== Error 2 - New and old type MK2 protocol mixed in the system ==== | ||
Line 40: | Line 45: | ||
- Communication cable error: Check the communication cables. Make sure to use commercial patch leads and not hand-crimped cables - VE.Bus cabling is very sensitive to physical wiring faults. | - Communication cable error: Check the communication cables. Make sure to use commercial patch leads and not hand-crimped cables - VE.Bus cabling is very sensitive to physical wiring faults. | ||
- | - DC fuse blown of one or more units in the system: When mains is available all units seems to work correctly, but as soon as mains fails, or as soon as the system decides to switch to Island mode for any other reason, the non powered | + | - DC fuse blown of one or more units in the system: When mains is available all units seems to work correctly. But as soon as mains fails, or as soon as the system decides to switch to Island mode for any other reason, the units with the blown DC fuse will be without power and switched off - and thus be " |
- When switching off so called " | - When switching off so called " | ||
Line 55: | Line 62: | ||
Line 60: | Line 69: | ||
Line 68: | Line 79: | ||
- download the latest VEConfigure and make sure it has downloaded all the latest Assistants. | - download the latest VEConfigure and make sure it has downloaded all the latest Assistants. | ||
+ | This error can also occur in newer firmwares when a VE.Bus BMS is connected (or dis-connected) and the assistant is not configured accordingly. | ||
==== Error 7 - External device connected, assistant required ==== | ==== Error 7 - External device connected, assistant required ==== | ||
Line 73: | Line 88: | ||
Solution: configure the Multi/ | Solution: configure the Multi/ | ||
==== Error 8 - Ground relay test failed ==== | ==== Error 8 - Ground relay test failed ==== | ||
Line 105: | Line 122: | ||
^ Model ^ Serial number ^ | ^ Model ^ Serial number ^ | ||
- | | MultiPlus-II 48V 3kVA | HQ2048 | | + | | MultiPlus-II 48V 3kVA | |
- | | MultiPlus-II 48V 3kVA GX | HQ2050 | | + | | MultiPlus-II 48V 3kVA GX | ≤ HQ2050 | |
- | | MultiPlus-II 24V 3kVA | HQ2101 | | + | | MultiPlus-II 24V 3kVA | |
- | | MultiPlus-II 48V 5kVA | HQ2116 | | + | | MultiPlus-II 48V 5kVA | |
- | | MultiPlus-II 48V 5kVA GX | HQ2122 | | + | | MultiPlus-II 48V 5kVA GX | ≤ HQ2122 | |
- | | EasySolar-II 48V 3kVA MPPT 250-70 GX | HQ2130 | | + | | EasySolar-II 48V 3kVA MPPT 250-70 GX | ≤ HQ2130 | |
| All other models | Any serial number | | | All other models | Any serial number | | ||
Line 176: | Line 193: | ||
Other possibility: | Other possibility: | ||
DC fuse blown of one or more units in the system. When mains is available all units seems to work correctly, but as soon as mains fails, the non powered units are disconnected from the system. | DC fuse blown of one or more units in the system. When mains is available all units seems to work correctly, but as soon as mains fails, the non powered units are disconnected from the system. | ||
==== Error 11 - Relay Test Fault - Installation error or possibly relay failure ==== | ==== Error 11 - Relay Test Fault - Installation error or possibly relay failure ==== | ||
Line 235: | Line 254: | ||
When the error persists after the all above steps, or when any other Failed step or extra explanation shows, then the unit may be faulty. Follow the [[https:// | When the error persists after the all above steps, or when any other Failed step or extra explanation shows, then the unit may be faulty. Follow the [[https:// | ||
==== Error 12 - Config mismatch with 2nd mcu ==== | ==== Error 12 - Config mismatch with 2nd mcu ==== | ||
Line 245: | Line 267: | ||
Make sure to select the option 'all settings' | Make sure to select the option 'all settings' | ||
Line 250: | Line 275: | ||
==== Error 15 - VE.Bus combination error ==== | ==== Error 15 - VE.Bus combination error ==== | ||
- | VE.Bus products or firmware versions can not be combined | + | Any combination error of VE.Bus products, firmware versions |
+ | * an Interface-1140 with old firmware is combined with a new Multi firmware or | ||
+ | * when external BMS commands are send while a VE.Bus BMS is connected or | ||
+ | * the connected VE.Bus product | ||
- | This error can occur for example when an Interface 1140 is combined with a VE.Bus BMS or when the connected VE.Bus product firmware versions are incompatible. The latter can in most cases be solved by updating the firmware. | + | __Recovery: |
Line 260: | Line 292: | ||
==== Error 17 - Phase master missing ==== | ==== Error 17 - Phase master missing ==== | ||
Line 277: | Line 311: | ||
=== Unable to solve it? === | === Unable to solve it? === | ||
If after all above steps you are still experiencing a VE.Bus Error 17, contact your dealer whom will contact Victron repairs; please provide photos of the installation and network cabling. Depending on the situation, they might advice to replace the [[venus-os: | If after all above steps you are still experiencing a VE.Bus Error 17, contact your dealer whom will contact Victron repairs; please provide photos of the installation and network cabling. Depending on the situation, they might advice to replace the [[venus-os: | ||
==== Error 19 - Slave does not have AC input! ==== | ==== Error 19 - Slave does not have AC input! ==== | ||
Line 286: | Line 324: | ||
Solution: Either connect the AC input to all units, or change the configuration of the synchronised units in VE.Bus System Configurator (note not VEConfigure), | Solution: Either connect the AC input to all units, or change the configuration of the synchronised units in VE.Bus System Configurator (note not VEConfigure), | ||
Line 332: | Line 380: | ||
Good units will measure discontinuity between the Line in and out terminals. And measure a few hundred ohms between the neutral In and Out AC terminals. | Good units will measure discontinuity between the Line in and out terminals. And measure a few hundred ohms between the neutral In and Out AC terminals. | ||
==== Error 25 - Firmware incompatibility ==== | ==== Error 25 - Firmware incompatibility ==== | ||
Line 338: | Line 388: | ||
Solution: update all devices to the latest available firmware. Instructions [[updating_firmware: | Solution: update all devices to the latest available firmware. Instructions [[updating_firmware: | ||
Should not occur. Switch all equipment off, and then on again; it will then resume operation. Contact Victron Energy if the problem persists. | Should not occur. Switch all equipment off, and then on again; it will then resume operation. Contact Victron Energy if the problem persists. | ||
~~DISQUS~~ | ~~DISQUS~~ |
ve.bus/ve.bus_error_codes.txt · Last modified: 2022-04-29 11:29 by marmour
