updating_firmware:updating_ve.bus_products [2023-06-26 08:33] – [VEFlash is deprecated in favour of VictronConnect] guy_stewartupdating_firmware:updating_ve.bus_products [2023-06-29 08:48] (current) – [Notes] marianka
Line 26: Line 26:
   * When updating parallel or three-phase installation, update each unit separately   * When updating parallel or three-phase installation, update each unit separately
   * After updating firmware, all settings will be reset to their factory defaults. The unit will be in stand-alone mode, and any //Assistant// settings will be removed.   * After updating firmware, all settings will be reset to their factory defaults. The unit will be in stand-alone mode, and any //Assistant// settings will be removed.
-  * It is not required to keep your Victron equipment updated to the latest firmware version. Stable systems should be left with their current firmware. Firmware updates should only be done when it is recommended to fix an issue you are experiencing, or add a new feature that is required by the installation.  +  * It is not required to keep your Victron equipment updated to the latest firmware version. Stable systems should be left with their current firmware. Firmware updates should only be done when it is recommended to fix an issue you are experiencing, or add a new feature that is required by the installation.
-Instruction video explaining how to update your VE.Bus products: +
-{{youtube>ZIn0mHLqU5Y}} +
 ==== Step by step instructions ==== ==== Step by step instructions ====
updating_firmware/updating_ve.bus_products.1687768382.txt.gz · Last modified: by guy_stewart
