| updating_firmware:updating_ve.bus_products [2016-08-06 15:29] – mvader | updating_firmware:updating_ve.bus_products [2023-06-29 08:48] (current) – [Notes] marianka | ||
| Line 1: | Line 1: | ||
| ====== Updating VE.Bus firmware, using VEFlash ====== | ====== Updating VE.Bus firmware, using VEFlash ====== | ||
| - | ==== Warning: not for end-users | + | ===== VEFlash is deprecated in favour of VictronConnect ====== |
| - | Important! Do not underestimate the complexity of updating firmware on a VE.Bus product (Inverters, Multis and Quattros). This document is intended for dealers and other Victron-trained installers and support-engineers. | + | |
| - | During | + | Being both faster and easier to use, we now recommend to use VictronConnect for firmware updates. Instructions in the [[https:// |
| + | Use VEFlash only for (older) models not supported by VictronConnect. | ||
| + | ===== Instructions for the old (deprecated) method ===== | ||
| + | **Warning: This operation must only be carried out by Victron-trained Engineers, Installers and Dealers, and must not be attempted by system Owners and Users.** | ||
| + | Updating firmware on a VE.Bus product (Inverters, Multis and Quattros) has system-critical implications: | ||
| + | * All settings will be lost - [[https:// | ||
| + | * Assistants and parallel or three-phase configuration will be lost. | ||
| + | Setting up a VE.Bus system | ||
| + | These instructions are for the VEFlash firmware update method, it is also possible to update [[https:// | ||
| ==== Notes ==== | ==== Notes ==== | ||
| - | * To update | + | * Updating |
| - | * New firmware files are available from [[https:// | + | * New firmware files are available from [[https:// |
| - | * To select the right file, look at the firmware version which is in your product now. Look for a seven digit number, for example 2654153. It is printed on a sticker on the control board. The first four digits indicate the model, and need to be the same. | + | * To select the right file, check the firmware version which is in the product now. Look for a seven digit number |
| - | * There are different firmware types available, read our PDF [[https:// | + | * There are different firmware types available. Read our PDF [[https:// |
| * Always use the latest version of VEFlash. It will automatically check online for updates on startup | * Always use the latest version of VEFlash. It will automatically check online for updates on startup | ||
| * When updating parallel or three-phase installation, | * When updating parallel or three-phase installation, | ||
| - | * After updating firmware, all settings will be reset to factory defaults. The unit will be reset to stand alone mode and any Assistant settings will be removed. | + | * After updating firmware, all settings will be reset to their factory defaults. The unit will be in stand-alone mode, and any //Assistant// settings will be removed. |
| - | + | * It is not required | |
| - | Instruction video explaining how to update | + | |
| - | {{youtube> | + | |
| ==== Step by step instructions ==== | ==== Step by step instructions ==== | ||
| Line 54: | Line 64: | ||
| - | ~~DISQUS~~ | ||
| Line 64: | Line 73: | ||
| + | ===== DISQUS ===== | ||
| + | ~~DISQUS~~ | ||
updating_firmware/updating_ve.bus_products.1470497356.txt.gz · Last modified: by mvader
