updating_firmware:updating_ve.bus_products [2020-05-25 01:49] – [Notes] guy_stewart | updating_firmware:updating_ve.bus_products [2023-06-29 10:48] (current) – [Notes] marianka | ||
===== VEFlash is deprecated in favour of VictronConnect ====== | ===== VEFlash is deprecated in favour of VictronConnect ====== | ||
- | Being both faster and easier to use, we now recommend to use VictronConnect for firmware updates. Instructions in the [[https://docs.victronenergy.com/ | + | Being both faster and easier to use, we now recommend to use VictronConnect for firmware updates. Instructions in the [[https://www.victronenergy.com/ |
Use VEFlash only for (older) models not supported by VictronConnect. | Use VEFlash only for (older) models not supported by VictronConnect. | ||
Line 16: | Line 16: | ||
Setting up a VE.Bus system requires both training and experience. We offer no direct support for un-trained individuals carrying-out reconfiguration. | Setting up a VE.Bus system requires both training and experience. We offer no direct support for un-trained individuals carrying-out reconfiguration. | ||
- | These instructions are for the VEFlash firmware update method, it is also possible to update [[https://docs.victronenergy.com/ | + | These instructions are for the VEFlash firmware update method, it is also possible to update [[https://www.victronenergy.com/ |
Line 26: | Line 26: | ||
* After updating firmware, all settings will be reset to their factory defaults. The unit will be in stand-alone mode, and any // | * After updating firmware, all settings will be reset to their factory defaults. The unit will be in stand-alone mode, and any // | ||
- | * It is not required to keep your Victron equipment updated to the latest firmware version. Stable systems should be left with their current firmware. Firmware updates should only be done when it is recommended to fix an issue you are experiencing, | + | * It is not required to keep your Victron equipment updated to the latest firmware version. Stable systems should be left with their current firmware. Firmware updates should only be done when it is recommended to fix an issue you are experiencing, |
- | Instruction video explaining how to update your VE.Bus products: | + | |
- | {{youtube> | + | |
==== Step by step instructions ==== | ==== Step by step instructions ==== |
