updating_firmware:updating_ve.bus_products [2020-05-25 01:49] – [Notes] guy_stewart | updating_firmware:updating_ve.bus_products [2021-01-22 09:33] – [Instructions for the old (deprecated) method] marmour | ||
===== VEFlash is deprecated in favour of VictronConnect ====== | ===== VEFlash is deprecated in favour of VictronConnect ====== | ||
- | Being both faster and easier to use, we now recommend to use VictronConnect for firmware updates. Instructions in the [[https://docs.victronenergy.com/ | + | Being both faster and easier to use, we now recommend to use VictronConnect for firmware updates. Instructions in the [[https://www.victronenergy.com/ |
Use VEFlash only for (older) models not supported by VictronConnect. | Use VEFlash only for (older) models not supported by VictronConnect. | ||
Line 16: | Line 16: | ||
Setting up a VE.Bus system requires both training and experience. We offer no direct support for un-trained individuals carrying-out reconfiguration. | Setting up a VE.Bus system requires both training and experience. We offer no direct support for un-trained individuals carrying-out reconfiguration. | ||
- | These instructions are for the VEFlash firmware update method, it is also possible to update [[https://docs.victronenergy.com/ | + | These instructions are for the VEFlash firmware update method, it is also possible to update [[https://www.victronenergy.com/ |
==== Notes ==== | ==== Notes ==== |
