updating_firmware:updating_ve.bus_products [2019-09-21 23:32] – [VEFlash is deprecated in favour of VictronConnect] mvader | updating_firmware:updating_ve.bus_products [2023-06-26 10:33] – [VEFlash is deprecated in favour of VictronConnect] guy_stewart | ||
===== VEFlash is deprecated in favour of VictronConnect ====== | ===== VEFlash is deprecated in favour of VictronConnect ====== | ||
- | Being both faster and easier to use, we now recommend to use VictronConnect for firmware updates. Instructions in the [[https://docs.victronenergy.com/ | + | Being both faster and easier to use, we now recommend to use VictronConnect for firmware updates. Instructions in the [[https://www.victronenergy.com/ |
Use VEFlash only for (older) models not supported by VictronConnect. | Use VEFlash only for (older) models not supported by VictronConnect. | ||
Line 16: | Line 16: | ||
Setting up a VE.Bus system requires both training and experience. We offer no direct support for un-trained individuals carrying-out reconfiguration. | Setting up a VE.Bus system requires both training and experience. We offer no direct support for un-trained individuals carrying-out reconfiguration. | ||
- | These instructions are for the VEFlash firmware update method, it is also possible to update [[https://docs.victronenergy.com/ | + | These instructions are for the VEFlash firmware update method, it is also possible to update [[https://www.victronenergy.com/ |
* Updating a VE.bus product can be done using VEFlash.exe which you will find in VE Configure Tools, available for download on our [[https:// | * Updating a VE.bus product can be done using VEFlash.exe which you will find in VE Configure Tools, available for download on our [[https:// | ||
- | * New firmware files are available from [[https:// | + | * New firmware files are available from [[https:// |
* To select the right file, check the firmware version which is in the product now. Look for a seven digit number (eg. 2654153) which you'll find printed on a sticker on the control board. The first four digits indicate the model, and must match the first four digits of the file you intend to upload. | * To select the right file, check the firmware version which is in the product now. Look for a seven digit number (eg. 2654153) which you'll find printed on a sticker on the control board. The first four digits indicate the model, and must match the first four digits of the file you intend to upload. | ||
* There are different firmware types available. Read our PDF [[https:// | * There are different firmware types available. Read our PDF [[https:// |
