updating_firmware:updating_ve.bus_products [2019-09-21 14:43] – [VEFlash is deprecated in favour of VictronConnect] mvader | updating_firmware:updating_ve.bus_products [2021-01-21 11:24] – [VEFlash is deprecated in favour of VictronConnect] marmour | ||
===== VEFlash is deprecated in favour of VictronConnect ====== | ===== VEFlash is deprecated in favour of VictronConnect ====== | ||
- | Being bother | + | Being both faster and easier to use, we now recommend to use VictronConnect for firmware updates. |
- | Use VEFlash for all (older) models not supported by VictronConnect. | + | |
+ | Use VEFlash only for (older) models not supported by VictronConnect. | ||
===== Instructions for the old (deprecated) method ===== | ===== Instructions for the old (deprecated) method ===== | ||
Line 21: | Line 20: | ||
* Updating a VE.bus product can be done using VEFlash.exe which you will find in VE Configure Tools, available for download on our [[https:// | * Updating a VE.bus product can be done using VEFlash.exe which you will find in VE Configure Tools, available for download on our [[https:// | ||
- | * New firmware files are available from [[https:// | + | * New firmware files are available from [[https:// |
* To select the right file, check the firmware version which is in the product now. Look for a seven digit number (eg. 2654153) which you'll find printed on a sticker on the control board. The first four digits indicate the model, and must match the first four digits of the file you intend to upload. | * To select the right file, check the firmware version which is in the product now. Look for a seven digit number (eg. 2654153) which you'll find printed on a sticker on the control board. The first four digits indicate the model, and must match the first four digits of the file you intend to upload. | ||
* There are different firmware types available. Read our PDF [[https:// | * There are different firmware types available. Read our PDF [[https:// |
