updating_firmware:updating_ve.bus_products [2018-03-20 10:53] – [Warning: This operation must only be carried out by Victron trained Engineers, Installers and Dealers, and must not be attempted by system owners and users.] justin_tyers_live_a_c | updating_firmware:updating_ve.bus_products [2023-06-26 10:33] – [VEFlash is deprecated in favour of VictronConnect] guy_stewart | ||
- | ==== Warning: This operation must only be carried out by Victron-trained Engineers, Installers and Dealers, and must not be attempted by system Owners and Users. | + | ===== VEFlash is deprecated in favour of VictronConnect ====== |
- | Important! | + | Being both faster and easier to use, we now recommend to use VictronConnect for firmware updates. Instructions in the [[https:// |
- | * All settings will be lost. | + | |
+ | Use VEFlash only for (older) models not supported by VictronConnect. | ||
+ | Updating firmware on a VE.Bus product (Inverters, Multis and Quattros) has system-critical implications: | ||
+ | * All settings will be lost - [[https:// | ||
* Assistants and parallel or three-phase configuration will be lost. | * Assistants and parallel or three-phase configuration will be lost. | ||
- | Note. Reconfiguring | + | |
+ | Setting up a VE.Bus system requires both training and experience. We offer no direct support | ||
+ | These instructions are for the VEFlash firmware update method, it is also possible | ||
- | * To update | + | * Updating |
- | * New firmware files are available from [[https:// | + | * New firmware files are available from [[https:// |
* To select the right file, check the firmware version which is in the product now. Look for a seven digit number (eg. 2654153) which you'll find printed on a sticker on the control board. The first four digits indicate the model, and must match the first four digits of the file you intend to upload. | * To select the right file, check the firmware version which is in the product now. Look for a seven digit number (eg. 2654153) which you'll find printed on a sticker on the control board. The first four digits indicate the model, and must match the first four digits of the file you intend to upload. | ||
* There are different firmware types available. Read our PDF [[https:// | * There are different firmware types available. Read our PDF [[https:// | ||
Line 16: | Line 26: | ||
* After updating firmware, all settings will be reset to their factory defaults. The unit will be in stand-alone mode, and any // | * After updating firmware, all settings will be reset to their factory defaults. The unit will be in stand-alone mode, and any // | ||
+ | * It is not required to keep your Victron equipment updated to the latest firmware version. Stable systems should be left with their current firmware. Firmware updates should only be done when it is recommended to fix an issue you are experiencing, | ||
Instruction video explaining how to update your VE.Bus products: | Instruction video explaining how to update your VE.Bus products: | ||
Line 56: | Line 67: | ||
- | ~~DISQUS~~ | ||
Line 66: | Line 76: | ||
+ | ~~DISQUS~~ |
