updating_firmware:updating_ve.bus_products [2016-09-04 11:42] – [Warning: not for end-users] mvader | updating_firmware:updating_ve.bus_products [2023-06-26 10:33] – [VEFlash is deprecated in favour of VictronConnect] guy_stewart | ||
- | ==== Warning: not for end-users | + | ===== VEFlash is deprecated in favour of VictronConnect ====== |
- | Important! Do not underestimate the complexity of updating firmware on a VE.Bus product (Inverters, Multis and Quattros). This document is intended for dealers and other Victron-trained installers and support-engineers. | + | |
- | After the firmware | + | Being both faster and easier to use, we now recommend to use VictronConnect for firmware updates. Instructions in the [[https:// |
+ | Use VEFlash only for (older) models not supported by VictronConnect. | ||
+ | Updating | ||
+ | * All settings will be lost - [[https:// | ||
+ | * Assistants and parallel or three-phase configuration | ||
+ | Setting up a VE.Bus system | ||
+ | These instructions are for the VEFlash firmware update method, it is also possible to update [[https:// | ||
- | * To update | + | * Updating |
- | * New firmware files are available from [[https:// | + | * New firmware files are available from [[https:// |
- | * To select the right file, look at the firmware version which is in your product now. Look for a seven digit number, for example 2654153. It is printed on a sticker on the control board. The first four digits indicate the model, and need to be the same. | + | * To select the right file, check the firmware version which is in the product now. Look for a seven digit number |
- | * There are different firmware types available, read our PDF [[https:// | + | * There are different firmware types available. Read our PDF [[https:// |
* Always use the latest version of VEFlash. It will automatically check online for updates on startup | * Always use the latest version of VEFlash. It will automatically check online for updates on startup | ||
- | * After updating firmware, all settings will be reset to factory defaults. The unit will be reset to stand alone mode and any Assistant settings will be removed. | + | * After updating firmware, all settings will be reset to their factory defaults. The unit will be in stand-alone mode, and any //Assistant// settings will be removed. |
+ | * It is not required to keep your Victron equipment updated to the latest firmware version. Stable systems should be left with their current firmware. Firmware updates should only be done when it is recommended to fix an issue you are experiencing, | ||
Instruction video explaining how to update your VE.Bus products: | Instruction video explaining how to update your VE.Bus products: | ||
Line 54: | Line 67: | ||
- | ~~DISQUS~~ | ||
Line 64: | Line 76: | ||
+ | ~~DISQUS~~ |
