updating_firmware:updating_ve.bus_products [2014-10-05 09:06] – mvader | updating_firmware:updating_ve.bus_products [2023-06-26 10:33] – [VEFlash is deprecated in favour of VictronConnect] guy_stewart | ||
+ | ===== VEFlash is deprecated in favour of VictronConnect ====== | ||
+ | Being both faster and easier to use, we now recommend to use VictronConnect for firmware updates. Instructions in the [[https:// | ||
+ | Use VEFlash only for (older) models not supported by VictronConnect. | ||
+ | Updating firmware on a VE.Bus product (Inverters, Multis and Quattros) has system-critical implications: | ||
+ | * All settings will be lost - [[https:// | ||
+ | * Assistants and parallel or three-phase configuration will be lost. | ||
+ | Setting up a VE.Bus system requires both training and experience. We offer no direct support for un-trained individuals carrying-out reconfiguration. | ||
+ | These instructions are for the VEFlash firmware update method, it is also possible to update [[https:// | ||
- | * To update | + | * Updating |
+ | * New firmware files are available from [[https:// | ||
+ | * To select the right file, check the firmware version which is in the product now. Look for a seven digit number (eg. 2654153) which you'll find printed on a sticker on the control board. The first four digits indicate the model, and must match the first four digits of the file you intend to upload. | ||
+ | * There are different firmware types available. Read our PDF [[https:// | ||
* Always use the latest version of VEFlash. It will automatically check online for updates on startup | * Always use the latest version of VEFlash. It will automatically check online for updates on startup | ||
- | * After updating firmware, all settings will be reset to defaults. The unit will be reset to stand alone mode and any Assistant settings will be removed. | + | * After updating firmware, all settings will be reset to their factory |
- | * There are different firmware types available, read our PDF [[http:// | + | * It is not required to keep your Victron equipment updated |
- | * When requesting firmware for a VE.Bus product, always include the current firmware | + | |
+ | Instruction video explaining how to update | ||
+ | {{youtube> | ||
- | Follow | + | Follow |
Line 19: | Line 41: | ||
- | Save Firmware file in an easy folder | + | Save the Firmware file in an easy to find folder. |
Line 27: | Line 49: | ||
- | Follow these steps carefully | + | Follow these steps carefully. |
Line 37: | Line 59: | ||
- | Once finished and OK is selected the Inverter/charger | + | Once finished and OK is selected the Inverter/Charger |
- | Note that all settings will be reset to defaults. Also. the unit will be reset to stand alone mode and any Assistant settings will be removed. | + | Note that all settings will be reset to defaults. Also that the unit will be reset to stand alone mode and any Assistant settings will be removed. |
- | ~~DISQUS~~ | ||
Line 56: | Line 76: | ||
+ | ~~DISQUS~~ |
