temperature_sensors
Temperature Sensors
Victron products can make use of temperature sense information to improve accuracy of battery charging. There is a range of various sensors that you can use depending on your product. Some come included, others can be purchased separately.
| Temperature Sensor | VE.bus Smart Dongle (1) | Smart Battery Sense (3M) | Smart Battery Sense (10M) | Temperature sensor QUA/PMP/GX Device | Temperature Sensor for BMV |
| Picture | | | | | |
| Products Supported | MultiPlus-II and VE.Bus devices | Bluetooth enabled VE.Direct MPPTs | Bluetooth enabled VE.Direct MPPTs | MultiPlus, Quattro, Compatible GX devices (Cerbo GX, Venus GX, etc), VE.Can MPPT, Skylla-S, Sylla-TG and Skylla-i | Battery Monitors with Temp Support - eg BMV-702 & 712, & VE.Bus Smart Dongle |
| Victron Part Number | ASS030537010 | SBS050100200 | SBS050150200 | ASS000001000 | ASS000100000 |
| Temperature on VRM | No | Yes | Yes | MultiPlus - No, Venus GX - Yes, VE.Can MPPT - *???* | Yes |
| Product Page | Product | Product | Product | Product | Product |
| Manual | Accessory Manual | Accessory Manual | Accessory Manual | See Inverter / Charger / Device Product Manual | See Battery Monitor Product Manual |
| Supports VE.Smart Networking | No | Yes | Yes | No | Yes with BMV-712; Yes with dongle for BMV-702 |
(1) You can mount the dongle itself directly on the battery. It has an internal temperature measurement. There are also terminals you can connect an external probe to as well, you must use the probe part - ASS000100000.
temperature_sensors.1593504958.txt.gz · Last modified: by guy_stewart
Add this page to your book
Manage book (
Help
