smart_battery_sense_manual
smart_battery_sense_manual [2018-03-04 22:29] – [4. Configuration] mvader | smart_battery_sense_manual [2021-02-16 06:45] (current) – guystewart | ||
- | ====== Smart Battery Sense manual ====== | + | Moved to: https:// |
- | The Smart Battery Sense is a wireless battery voltage- and temperature- sensor for Victron MPPT Solar Chargers. | + | |
- | The connection between the Smart Battery Sense and the Solar Charger(s) wireless: VE.Smart Network, a wireless technology that is based on Bluetooth Smart. | + | |
- | Simple to install & configure, the Smart Battery Sense comes with an inline fuse and pre-crimped eyelets. And adhesive tape on the back, to mount it on the battery. | + | |
- | === System design & component selection === | + | |
- | * The Smart Battery Sense is not needed, nor allowed, in systems that also have a Color Control GX or Venus GX, see [[victronconnect: | + | |
- | * The Smart Battery Sense is not needed for installations that already have a BMV-712 with its temperature sensor accessory. | + | |
- | * For installations with a BMV-702 + temperature sensor accessory, consider adding a [[https:// | + | |
- | Connect the unit's two eyelets to your battery terminals and attach it directly onto the battery-body using its self-adhesive strip. | + | |
- | For battery banks consisting of multiple individual batteries, connect the Smart Battery Sense unit on any one of the batteries. | + | |
- | In case the supplied bat+ and bat- cables are not long enough, their length can be increased. Make sure to use the same, or thicker, gauge cable. | + | |
- | See this below video. Also, see the step by step procedure as documented in the [[victronconnect: | + | |
- | {{youtube> | + | |
- | ===== 5. Trouble shooting ===== | + | |
