open_source:start
open_source:start [2020-01-28 17:04] – [4.2 VE.Direct (MPPT Solar Chargers and BMV Battery Monitors)] PvMonit new version kepon | open_source:start [2023-06-01 06:40] (current) – [Q1. Why is the Bluetooth API not public?] guy_stewart | ||
Line 12: | Line 12: | ||
===== 1. Venus OS: the software on our GX product range and also for the Raspberry Pi===== | ===== 1. Venus OS: the software on our GX product range and also for the Raspberry Pi===== | ||
- | Venus OS is the Victron Energy Unix like distro with a linux kernel. | + | Venus OS is the Victron Energy Unix like distro with a linux kernel. |
While being a very successful project for us in its standard configuration, | While being a very successful project for us in its standard configuration, | ||
Line 19: | Line 19: | ||
- | Full information about Venus OS; and compatible hardware as well as how to install on a Raspberry P is is here: https:// | + | Full information about Venus OS; and compatible hardware as well as how to install on a Raspberry P is here: https:// |
Line 77: | Line 77: | ||
* https:// | * https:// | ||
+ | * [[https:// | ||
+ | Battery/ | ||
Other: | Other: | ||
Line 82: | Line 87: | ||
* PvMonit : small real-time web interface and export to emonCMS for history (Brick from [[https:// | * PvMonit : small real-time web interface and export to emonCMS for history (Brick from [[https:// | ||
+ | * http:// | ||
* PvMonit now knows how to exploit the solar surplus when you are not using it with the "home automation" | * PvMonit now knows how to exploit the solar surplus when you are not using it with the "home automation" | ||
Line 88: | Line 94: | ||
+ | * https:// | ||
Line 98: | Line 105: | ||
* Victron Blog about the victronPi above: [[https:// | * Victron Blog about the victronPi above: [[https:// | ||
* velog: Serial log application for VE.Direct devices [[https:// | * velog: Serial log application for VE.Direct devices [[https:// | ||
- | ===== FAQ ===== | + | ===== Bluetooth Protocol |
- | ==== Q1. Why is the Bluetooth API not public? ==== | + | |
- | Making the bluetooth API an official public one would mean that we can’t change it as simply as we can today; and also it means that we’ll get questions about it: bluetooth is not simple. Far more complicated than a serial port. | + | |
- | And then only our developers will be able to answer them: taking away development resources. Hence we chose to not make the Bluetooth API public. | + | |
+ | * https:// | ||
~~DISQUS~~ | ~~DISQUS~~ |
open_source/start.txt · Last modified: 2023-06-01 06:40 by guy_stewart
