open_source:start
open_source:start [2019-07-01 08:55] – [Signal K] john_r | open_source:start [2023-06-01 06:40] (current) – [Q1. Why is the Bluetooth API not public?] guy_stewart | ||
Line 9: | Line 9: | ||
Looking for Victron protocol documentation? | Looking for Victron protocol documentation? | ||
- | ===== Venus OS: the software on our GX product range and also for the Raspberry Pi===== | + | Also, see our [[https:// |
- | Venus OS is the Victron Energy Unix like distro with a linux kernel. | + | |
+ | ===== 1. Venus OS: the software on our GX product range and also for the Raspberry Pi===== | ||
+ | Venus OS is the Victron Energy Unix like distro with a linux kernel. | ||
While being a very successful project for us in its standard configuration, | While being a very successful project for us in its standard configuration, | ||
Line 17: | Line 19: | ||
- | Full information about Venus OS; and compatible hardware as well as how to install on a Raspberry P is is here: https:// | + | Full information about Venus OS; and compatible hardware as well as how to install on a Raspberry P is here: https:// |
+ | ==== 1.1 Dockerised Influx database & Grafana dashboard for Venus OS / GX Devices ===== | ||
+ | See https:// | ||
- | ===== Signal K ===== | + | ===== 2. VRM Portal (https:// |
+ | While in itself not being an open source project, the VRM Portal database can be queried using the [[https:// | ||
+ | Also, you can interface to the GX product range using MQTT, see the [[https:// | ||
+ | ===== 3. Signal K ===== | ||
Signal K is a modern and open data format for marine use. Built on standard web technologies including JSON, WebSockets and HTTP, Signal K provides a method for sharing information independently of the underlying communications protocol (e.g. NMEA0183, NMEA2000, SeaTalk, I2C, 1-Wire, ZigBee, etc) in a way that is friendly to WiFi, cellphones, tablets, and the Internet. More information at [[http:// | Signal K is a modern and open data format for marine use. Built on standard web technologies including JSON, WebSockets and HTTP, Signal K provides a method for sharing information independently of the underlying communications protocol (e.g. NMEA0183, NMEA2000, SeaTalk, I2C, 1-Wire, ZigBee, etc) in a way that is friendly to WiFi, cellphones, tablets, and the Internet. More information at [[http:// | ||
Line 32: | Line 42: | ||
* Blog - Signal K: Embracing connectivity with Victron Energy: [[https:// | * Blog - Signal K: Embracing connectivity with Victron Energy: [[https:// | ||
- | ===== VRM Portal (https:// | + | ===== 4. Other Victron related open source projects ===== |
- | While in itself not being an open source project, the VRM Portal database can be queried using the [[https:// | + | |
- | Also, you can interface to the GX product range using MQTT, see the [[https:// | + | |
- | ===== Dockerised Influx database & Grafana dashboard for Venus OS / GX Devices ===== | + | |
- | See https:// | + | |
- | ===== Why is the Bluetooth API not public? ===== | + | |
- | Making the bluetooth API an official public one would mean that we can’t change it as simply as we can today; and also it means that we’ll get questions about it: bluetooth is not simple. Far more complicated than a serial port. | + | |
- | And then only our developers will be able to answer them: taking away development resources. Hence we chose to not make the Bluetooth API public. | + | |
- | ===== Other Victron related open source projects ===== | + | |
Many, many people all over the world are writing code to integrate Victron products and protocols into their systems. Below a list of public projects, aiming to help each other. | Many, many people all over the world are writing code to integrate Victron products and protocols into their systems. Below a list of public projects, aiming to help each other. | ||
Line 56: | Line 50: | ||
Want to list your project here? Please go ahead and change this page yourself! See Login on upper right. | Want to list your project here? Please go ahead and change this page yourself! See Login on upper right. | ||
- | ==== Multis / Quattros / MK2 ==== | + | ==== 4.1 Multis / Quattros / MK2 ==== |
* https:// | * https:// | ||
Line 77: | Line 71: | ||
want to list your project here? Please go ahead and change this page yourself! | want to list your project here? Please go ahead and change this page yourself! | ||
- | ==== VE.Direct (MPPT Solar Chargers and BMV Battery Monitors) ==== | + | ==== 4.2 VE.Direct (MPPT Solar Chargers and BMV Battery Monitors) ==== |
Arduino: | Arduino: | ||
Line 83: | Line 77: | ||
+ | * [[https:// | ||
+ | Battery/ | ||
Other: | Other: | ||
Line 88: | Line 87: | ||
* PvMonit : small real-time web interface and export to emonCMS for history (Brick from [[https:// | * PvMonit : small real-time web interface and export to emonCMS for history (Brick from [[https:// | ||
- | * http:// | + | * http:// |
+ | * https:// | ||
+ | * PvMonit now knows how to exploit the solar surplus when you are not using it with the "home automation" | ||
+ | * https:// | ||
+ | * https:// | ||
+ | * https:// | ||
Line 101: | Line 105: | ||
* Victron Blog about the victronPi above: [[https:// | * Victron Blog about the victronPi above: [[https:// | ||
* velog: Serial log application for VE.Direct devices [[https:// | * velog: Serial log application for VE.Direct devices [[https:// | ||
+ | ===== Bluetooth Protocol ===== | ||
+ | * https:// | ||
~~DISQUS~~ | ~~DISQUS~~ |
open_source/start.txt · Last modified: 2023-06-01 06:40 by guy_stewart
