open_source:start
open_source:start [2019-06-16 19:15] – [VE.Direct (MPPT Solar Chargers and BMV Battery Monitors)] mvader | open_source:start [2019-07-01 08:55] – [Signal K] john_r | ||
Line 9: | Line 9: | ||
Looking for Victron protocol documentation? | Looking for Victron protocol documentation? | ||
- | ===== Color Control GX, BBB, RaspberryPi: the Venus OS ===== | + | ===== Venus OS: the software on our GX product range and also for the Raspberry Pi===== |
- | Venus OS is the Victron Energy Unix like distro with a linux kernel. Its the heart of our [[https:// | + | Venus OS is the Victron Energy Unix like distro with a linux kernel. Its the software that runs on our of our [[venus-os:start|GX Product range]]: central and remote monitoring systems. |
While being a very successful project for us in its standard configuration, | While being a very successful project for us in its standard configuration, | ||
Line 16: | Line 16: | ||
* Add logic on the product, for example to control the relay, or do other things. | * Add logic on the product, for example to control the relay, or do other things. | ||
- | Full information about the Venus OS; and compatible boards and hardware is here: https:// | ||
- | In case you want to develop something, please share your thoughts with us. We want to help making it a success, and preferably also include it in our main repositories and images. | + | Full information about Venus OS; and compatible hardware as well as how to install on a Raspberry P is is here: https:// |
- | ==== More information | + | |
- | * [[https:// | + | |
- | * [[ccgx:root_access|Root access]] | + | ===== Signal K ===== |
- | * [[open_source: | + | |
- | * [[open_source: | + | Signal K is a modern and open data format for marine use. Built on standard web technologies including JSON, WebSockets and HTTP, Signal K provides a method for sharing information independently of the underlying communications protocol (e.g. NMEA0183, NMEA2000, SeaTalk, I2C, 1-Wire, ZigBee, etc) in a way that is friendly to WiFi, cellphones, tablets, and the Internet. More information at [[http:// |
- | * developers mailing list: https://groups.google.com/forum/m/#!forum/victron-dev-venus | + | |
- | * [[https:// | + | * Signal K Node Server plugin: |
- | * [[https://github.com/victronenergy/venus/wiki/raspberrypi|Installing CCGX functionality on a raspberry pi]] | + | * Raspberry Pi Venus image: [[https://github.com/victronenergy/venus/wiki/raspberrypi-install-venus-image]] |
- | * [[open_source:ccgx:ccgx_traffic_counting|Traffic counting on the CCGX]] | + | * Signal K plugin for VE.Direct Serial to USB interface: |
- | * [[https://github.com/sbender9/signalk-venus-plugin|SignalK Venus Plugin]] | + | * Blog - Sailing with Signal K: [[https://www.victronenergy.com/blog/2019/06/ |
+ | * Blog - Signal K: Embracing connectivity with Victron Energy: [[https://www.victronenergy.com/blog/2018/ | ||
===== VRM Portal (https:// | ===== VRM Portal (https:// | ||
- | * [[https:// | ||
+ | While in itself not being an open source project, the VRM Portal database can be queried using the [[https:// | ||
+ | Also, you can interface to the GX product range using MQTT, see the [[https:// | ||
+ | ===== Dockerised Influx database & Grafana dashboard for Venus OS / GX Devices ===== | ||
+ | See https:// | ||
===== Why is the Bluetooth API not public? ===== | ===== Why is the Bluetooth API not public? ===== | ||
Line 95: | Line 99: | ||
* SignalK: https:// | * SignalK: https:// | ||
* victronPi: a Raspberry Pi driven graphical display of data from Victron equipment installed in a campervan [[http:// | * victronPi: a Raspberry Pi driven graphical display of data from Victron equipment installed in a campervan [[http:// | ||
+ | * Victron Blog about the victronPi above: [[https:// | ||
* velog: Serial log application for VE.Direct devices [[https:// | * velog: Serial log application for VE.Direct devices [[https:// | ||
- | ==== SignalK ==== | ||
- | Signal K is a modern and open data format for marine use. Built on standard web technologies including JSON, WebSockets and HTTP, Signal K provides a method for sharing information independently of the underlying communications protocol (e.g. NMEA0183, NMEA2000, SeaTalk, I2C, 1-Wire, ZigBee, etc) in a way that is friendly to WiFi, cellphones, tablets, and the Internet. More information on [[http:// | ||
- | * SignalK Venus Plugin: https:// | ||
- | * SignalK plug-in for USB- connected MPPT Solar Charger: https:// | ||
~~DISQUS~~ | ~~DISQUS~~ |
open_source/start.txt · Last modified: 2023-06-01 06:40 by guy_stewart
