open_source:start
open_source:start [2019-05-31 07:23] – mvader | open_source:start [2022-06-14 18:35] – mano8 | ||
Line 9: | Line 9: | ||
Looking for Victron protocol documentation? | Looking for Victron protocol documentation? | ||
- | ===== Color Control GX, BBB, RaspberryPi: the Venus OS ===== | + | Also, see our [[https:// |
- | Venus OS is the Victron Energy Unix like distro with a linux kernel. | + | |
+ | ===== 1. Venus OS: the software on our GX product range and also for the Raspberry Pi===== | ||
+ | Venus OS is the Victron Energy Unix like distro with a linux kernel. | ||
While being a very successful project for us in its standard configuration, | While being a very successful project for us in its standard configuration, | ||
Line 16: | Line 18: | ||
* Add logic on the product, for example to control the relay, or do other things. | * Add logic on the product, for example to control the relay, or do other things. | ||
- | Full information about the Venus OS; and compatible boards and hardware is here: https:// | ||
- | In case you want to develop something, please share your thoughts with us. We want to help making it a success, and preferably also include it in our main repositories and images. | + | Full information about Venus OS; and compatible hardware as well as how to install on a Raspberry P is here: https:// |
- | ==== More information ==== | ||
- | * [[open_source: | ||
- | * [[https:// | ||
- | * [[ccgx: | ||
- | * developers mailing list: https:// | ||
- | ===== VRM Portal (https:// | + | ==== 1.1 Dockerised Influx database & Grafana dashboard for Venus OS / GX Devices |
- | * [[https:// | + | |
- | ===== Why is the Bluetooth API not public? ===== | + | See https:// |
- | Making the bluetooth API an official public one would mean that we can’t change it as simply as we can today; and also it means that we’ll get question about it: bluetooth is not simple. Far more complicated than a serial port. | + | ===== 2. VRM Portal (https://vrm.victronenergy.com/) ===== |
- | And then only our developers will be able to answer them: taking away development resources. Hence we chose to not make the Bluetooth API public. | + | While in itself not being an open source project, the VRM Portal database can be queried using the [[https:// |
+ | Also, you can interface | ||
+ | ===== 3. Signal K ===== | ||
+ | Signal K is a modern and open data format for marine use. Built on standard web technologies including JSON, WebSockets and HTTP, Signal K provides a method for sharing information independently of the underlying communications protocol (e.g. NMEA0183, NMEA2000, SeaTalk, I2C, 1-Wire, ZigBee, etc) in a way that is friendly | ||
+ | * Signal K Node Server plugin: [[https:// | ||
+ | * Raspberry Pi Venus image: [[https:// | ||
+ | * Signal K plugin for VE.Direct Serial to USB interface: [[https:// | ||
+ | * Blog - Sailing with Signal K: [[https:// | ||
+ | * Blog - Signal K: Embracing connectivity with Victron Energy: [[https:// | ||
- | ===== Other Victron related open source projects ===== | + | ===== 4. Other Victron related open source projects ===== |
Many, many people all over the world are writing code to integrate Victron products and protocols into their systems. Below a list of public projects, aiming to help each other. | Many, many people all over the world are writing code to integrate Victron products and protocols into their systems. Below a list of public projects, aiming to help each other. | ||
- | Tip: makre sure to search for ' | + | Tip: make sure to search for ' |
Want to list your project here? Please go ahead and change this page yourself! See Login on upper right. | Want to list your project here? Please go ahead and change this page yourself! See Login on upper right. | ||
- | ==== Multis / Quattros / MK2 ==== | + | ==== 4.1 Multis / Quattros / MK2 ==== |
* https:// | * https:// | ||
Line 71: | Line 69: | ||
- | * want to list your project here? Please go ahead and change this page yourself! | + | want to list your project here? Please go ahead and change this page yourself! |
- | ==== VE.Direct (MPPT Solar Chargers and BMV Battery Monitors) ==== | + | ==== 4.2 VE.Direct (MPPT Solar Chargers and BMV Battery Monitors) ==== |
Arduino: | Arduino: | ||
+ | * [[https:// | ||
+ | Battery/ | ||
Other: | Other: | ||
Line 83: | Line 87: | ||
* PvMonit : small real-time web interface and export to emonCMS for history (Brick from [[https:// | * PvMonit : small real-time web interface and export to emonCMS for history (Brick from [[https:// | ||
- | * http:// | + | * http:// |
+ | * https:// | ||
+ | * PvMonit now knows how to exploit the solar surplus when you are not using it with the "home automation" | ||
+ | * https:// | ||
+ | * https:// | ||
+ | * https:// | ||
Line 94: | Line 103: | ||
* SignalK: https:// | * SignalK: https:// | ||
* victronPi: a Raspberry Pi driven graphical display of data from Victron equipment installed in a campervan [[http:// | * victronPi: a Raspberry Pi driven graphical display of data from Victron equipment installed in a campervan [[http:// | ||
+ | * Victron Blog about the victronPi above: [[https:// | ||
* velog: Serial log application for VE.Direct devices [[https:// | * velog: Serial log application for VE.Direct devices [[https:// | ||
- | ==== SignalK | + | ===== FAQ ===== |
- | Signal K is a modern | + | ==== Q1. Why is the Bluetooth API not public? ==== |
+ | Making the bluetooth API an official public one would mean that we can’t change it as simply as we can today; | ||
+ | And then only our developers will be able to answer them: taking away development resources. Hence we chose to not make the Bluetooth API public. | ||
- | * SignalK Venus Plugin: https:// | ||
- | * SignalK plug-in for USB- connected MPPT Solar Charger: https:// | ||
~~DISQUS~~ | ~~DISQUS~~ |
open_source/start.txt · Last modified: 2023-06-01 06:40 by guy_stewart
