mppt-error-codes
mppt-error-codes [2019-11-08 14:43] – tabreu | mppt-error-codes [2025-06-12 16:13] (current) – [Err 74 - Too many in parallel] rvanzundert | ||
+ | * Remote | ||
Line 26: | Line 40: | ||
Line 32: | Line 58: | ||
+ | Possible solutions | ||
Line 52: | Line 85: | ||
The feature of this safety protection is to detect a shorted cell; and stop charging. | The feature of this safety protection is to detect a shorted cell; and stop charging. | ||
==== Err 28 - Power stage issue ==== | ==== Err 28 - Power stage issue ==== | ||
Line 71: | Line 130: | ||
Note that this error was introduced in v1.36. So when doing an update, it might look like the firmware update caused this issue; but it doesn' | Note that this error was introduced in v1.36. So when doing an update, it might look like the firmware update caused this issue; but it doesn' | ||
+ | Possible causes: | ||
Line 76: | Line 143: | ||
- | * Error 39: The charger will automatically resume operation once the battery voltage drops below the float level for 1 minute. | + | * Error 39: The charger will automatically resume operation once the battery voltage drops below its maximum voltage setting (normally Equalisation or Absorption voltages). It can also takes a minute |
Line 100: | Line 240: | ||
+ | This error also appears if MPPTs are connected to a GX device while configured for a VE.Smart network. Disable the VE.Smart networking features and use DVCC on the GX instead. | ||
+ | __Background__ | ||
+ | ==== Err 74 - Too many units in parallel ==== | ||
+ | The firmware does not support parallel units and a grid connection, so any combination of a Multi RS with a grid connection with more than one unit in parallel will trigger this error code on the Multi RS. The Multi RS only supports 3 units in 3-phase configuration at the moment. | ||
- | The charger detects multiple conflicting network sources trying | + | The inverters remain operational, |
- | Applies to SmartSolar MPPTs and SmartSolar MPPTs VE.Can. | + | ==== Err 75 - Network misconfigured ==== |
+ | Applies to Multi RS models. Firmware versions 1.19 and higher. | ||
- | The typical reason for the error to show is that the charger is configured to operate | + | Three phase operation |
- | Resolution: disable the parallel operation by connecting VictronConnect, going to settings, then " | + | The inverters remain operational, they won't connect |
- | For SmartSolar MPPT VE.Can only, also make sure its not connected to a [[https:// | + | ==== Err 76 - Network incomplete ==== |
+ | Applies to Inverter RS and Multi RS models. | ||
- | Once the conflict | + | The inverters shut down because there are insufficient units to operate a networked setup. Check if all required units are powered on and that the CAN interface cables are connected properly. |
+ | All units remain off until the installation | ||
+ | Related configuration settings in VictronConnect are " | ||
Line 144: | Line 350: | ||
- | ~~DISQUS~~ | + | |
mppt-error-codes.1573220582.txt.gz · Last modified: by tabreu
