mppt-error-codes
mppt-error-codes [2018-04-24 09:10] – rvanzundert | mppt-error-codes [2024-02-12 05:48] (current) – [Err 54 - Inverter output voltage] guy_stewart | ||
+ | * Remote | ||
Line 26: | Line 40: | ||
Line 32: | Line 58: | ||
- | Disconnect | + | |
- | If the error persists the charge controller is probably faulty. | + | |
+ | Possible solutions | ||
+ | === AC Chargers === | ||
Line 59: | Line 116: | ||
+ | Possible causes: | ||
Line 64: | Line 143: | ||
- | ==== Err 38, Err 39 - Input shutdown | + | ==== Err 35 - PV over-power ==== |
- | * Error 39: The charger will automatically resume operation once the battery voltage drops below the float level for 1 minute. | + | * Error 39: The charger will automatically resume operation once the battery voltage drops below its maximum voltage setting (normally Equalisation or Absorption voltages). It can also takes a minute |
Line 88: | Line 240: | ||
+ | __Background__ | ||
Line 111: | Line 325: | ||
- | The unit is faulty, contact your dealer for a replacement. | + | If the unit does not work and error 116 pops up as the active error the unit is faulty, contact your dealer for a replacement. |
Line 117: | Line 345: | ||
mppt-error-codes.1524553850.txt.gz · Last modified: 2018-04-24 09:10 by rvanzundert
