mppt-error-codes
mppt-error-codes [2018-04-19 11:18] – [Err 38 - Input shutdown due to battery over-voltage] mvader | mppt-error-codes [2024-02-12 05:48] (current) – [Err 54 - Inverter output voltage] guy_stewart | ||
+ | * Remote | ||
Line 26: | Line 40: | ||
Line 32: | Line 58: | ||
- | Disconnect | + | |
- | If the error persists the charge controller is probably faulty. | + | |
+ | Possible solutions | ||
+ | === AC Chargers === | ||
Line 59: | Line 116: | ||
+ | Possible causes: | ||
Line 64: | Line 143: | ||
- | ==== Err 38 - Input shutdown due to battery | + | ==== Err 35 - PV over-power ==== |
- | To protect the battery from over-charging the panel input is shorted. To recover from this condition first disconnect the solar panels and disconnect the battery. Wait for 3 minutes, then reconnect the battery first and next the panels. | + | |
- | A common reason for this error to occur is that the Battery voltage (12/24/48V) is set, or auto-detected, | + | Applies |
- | Another reason is that there is another device connected to the battery, which is configured to a higher voltage. For example a MultiPlus, configured to equalise at 17 Volts, while in the MPPT | + | Please upgrade your firmware to at least v1.08 as the issues causing this error have been addressed. |
+ | If you are using firmware v1.08 or newer this error indicates | ||
+ | Error recovery: | ||
Line 82: | Line 240: | ||
+ | __Background__ | ||
Line 105: | Line 325: | ||
- | The unit is faulty, contact your dealer for a replacement. | + | If the unit does not work and error 116 pops up as the active error the unit is faulty, contact your dealer for a replacement. |
Line 111: | Line 345: | ||
mppt-error-codes.1524129501.txt.gz · Last modified: 2018-04-19 11:18 by mvader
