mppt-error-codes
mppt-error-codes [2022-02-01 12:40] – [Err 201 - Internal DC voltage error] rvanzundert | mppt-error-codes [2024-02-12 05:48] (current) – [Err 54 - Inverter output voltage] guy_stewart | ||
Line 13: | Line 13: | ||
* Orion Smart DC-DC Charger | * Orion Smart DC-DC Charger | ||
Line 147: | Line 153: | ||
If you are using firmware v1.08 or newer this error indicates that the internal dc voltage is too high. This error will auto-reset. If the error does not auto-reset disconnect the charge controller from all power-sources, | If you are using firmware v1.08 or newer this error indicates that the internal dc voltage is too high. This error will auto-reset. If the error does not auto-reset disconnect the charge controller from all power-sources, | ||
- | ==== Err 38, Err 39 - PV Input shutdown ==== | + | |
- | To protect the battery from over-charging the panel input is shorted. | + | ==== Err 38, Err 39 and Err 80 to Err 87 - PV Input shutdown ==== |
Line 170: | Line 179: | ||
Check the PV array cabling and panel isolation, the inverter restarts automatically once the issue is resolved. | Check the PV array cabling and panel isolation, the inverter restarts automatically once the issue is resolved. | ||
- | ==== Err 42 - Inverter shutdown (Ground Fault) ==== | + | ==== Err 42 - Inverter shutdown (PV isolation) ==== |
- | The ground leakage current exceeds the allowed 30mA limit. | + | The ground leakage current |
Check the PV array cabling and panel isolation. | Check the PV array cabling and panel isolation. | ||
Check the installation and restart the unit using the power-switch. | Check the installation and restart the unit using the power-switch. | ||
Line 201: | Line 210: | ||
The inverter will restart after 30 seconds. The inverter will not stay off after multiple retries. | The inverter will restart after 30 seconds. The inverter will not stay off after multiple retries. | ||
- | ==== Err 53, Err 54 - Inverter output voltage ==== | + | ==== Err 53 - Inverter output voltage ==== |
If the battery voltage is getting low and a large load is applied to the AC output the inverter is unable to maintain the proper output voltage. | If the battery voltage is getting low and a large load is applied to the AC output the inverter is unable to maintain the proper output voltage. | ||
Re-charge the battery or reduce the AC loads to continue operation. | Re-charge the battery or reduce the AC loads to continue operation. | ||
==== Err 55, Err 56, Err 58 - Inverter self test failed ==== | ==== Err 55, Err 56, Err 58 - Inverter self test failed ==== | ||
The inverter performs diagnostic tests before it activates its output. In the case that one of these tests fails an error message is displayed and the inverter does not turn on. | The inverter performs diagnostic tests before it activates its output. In the case that one of these tests fails an error message is displayed and the inverter does not turn on. | ||
Line 215: | Line 229: | ||
This error will not auto-reset. Check the installation and restart the unit using the power-switch. | This error will not auto-reset. Check the installation and restart the unit using the power-switch. | ||
Line 222: | Line 240: | ||
- | The charger is configured to be controlled by a BMS, but it does not receive any control messages | + | |
+ | This error shows when the charger is configured to be controlled by a BMS, but does not receive any BMS control messages. | ||
Solar Chargers only show this error when there is solar power available and thus the device is ready to initiate charging. It does not show at night. And in case there is a permanent problem, the error will raise in the morning and clear at night, and so forth. | Solar Chargers only show this error when there is solar power available and thus the device is ready to initiate charging. It does not show at night. And in case there is a permanent problem, the error will raise in the morning and clear at night, and so forth. | ||
- | Check the connection between the charger and the BMS. | + | Solution: check the connection between the charger and the BMS. |
__How to reconfigure the charger to standalone mode__ | __How to reconfigure the charger to standalone mode__ | ||
Line 236: | Line 255: | ||
Our Chargers and Solar Chargers automatically configure themselves to be BMS-controlled when they are connected to one; either direct or via a GX Device. And that setting is semi-permanent: | Our Chargers and Solar Chargers automatically configure themselves to be BMS-controlled when they are connected to one; either direct or via a GX Device. And that setting is semi-permanent: | ||
- | Here is what needs to be done to make the charger | + | When removing |
* Chargers with LCD display: go into the setup menu, and change setting ‘BMS’ from ‘Y’ to ‘N’ (setup item 31). | * Chargers with LCD display: go into the setup menu, and change setting ‘BMS’ from ‘Y’ to ‘N’ (setup item 31). | ||
Line 256: | Line 276: | ||
Now, if the same information is being received from two interfaces that have the same priority level (as VE.Can and VE.Direct), the charger does not know how to prioritize those, causing error 68 to be triggered. | Now, if the same information is being received from two interfaces that have the same priority level (as VE.Can and VE.Direct), the charger does not know how to prioritize those, causing error 68 to be triggered. | ||
Line 275: | Line 337: | ||
To fix this the update needs to be retried, download the correct firmware for your device from the [[https:// | To fix this the update needs to be retried, download the correct firmware for your device from the [[https:// | ||
- | When your Venus GX device is connected to VRM, you can do a remote firmware update using this firmware file. You can do this via the VRM website or using the VRM tab in VictronConnect. VictronConnect can also be used together with the firmware file to update using a Bluetooth connection. | + | When your GX device is connected to VRM, you can do a remote firmware update using this firmware file. You can do this via the VRM website or using the VRM tab in VictronConnect. VictronConnect can also be used together with the firmware file to update using a Bluetooth connection. |
The procedure to add the file to VictronConnect and start the update is described here: [[https:// | The procedure to add the file to VictronConnect and start the update is described here: [[https:// | ||
Line 301: | Line 363: | ||
==== Err 201 - Internal DC voltage error ==== | ==== Err 201 - Internal DC voltage error ==== | ||
- | Applies to the MPPT RS, Inverter RS and Multi RS | + | Applies to the MPPT RS, Inverter RS and Multi RS. |
- | Internal DC voltage measurement | + | If the error still occurs after updating to v1.08 or later, then it means that a measurement circuit inside the unit is broken. |
- | Make sure to update the firmware to at least v1.08, in previous firmwares | + | This error will not auto-reset. Check the installation and restart the unit using the power-switch. If the error persists, even after above mentioned firmware update, the unit is most likely faulty |
- | The unit might have seemingly worked fine before the firmware update; but it is really broken, | + | ==== Err 202 - Internal GFCI sensor error ==== |
+ | The sensor used to measure residual current did not pass the internal | ||
This error will not auto-reset. Check the installation and restart the unit using the power-switch. If the error persists the unit is probably faulty and must be sent in for repair/ | This error will not auto-reset. Check the installation and restart the unit using the power-switch. If the error persists the unit is probably faulty and must be sent in for repair/ |
