mppt-error-codes
mppt-error-codes [2021-06-25 08:40] – rvanzundert | mppt-error-codes [2023-09-14 14:07] – rvanzundert | ||
+ | * Remote | ||
Line 45: | Line 58: | ||
+ | Possible solutions | ||
Line 97: | Line 117: | ||
==== Err 27 - Charger short circuit ==== | ==== Err 27 - Charger short circuit ==== | ||
If the error does not auto-reset disconnect the charge controller from all power-sources, | If the error does not auto-reset disconnect the charge controller from all power-sources, | ||
Line 109: | Line 131: | ||
==== Err 29 - Over-Charge protection ==== | ==== Err 29 - Over-Charge protection ==== | ||
- | This error will auto-reset. | + | This error will auto-reset |
To protect the battery from over-charging the battery is disconnected. | To protect the battery from over-charging the battery is disconnected. | ||
- | A possible cause is an over-sized PV array configuration, | ||
+ | Possible causes: | ||
Line 118: | Line 143: | ||
==== Err 35 - PV over-power ==== | ==== Err 35 - PV over-power ==== | ||
- | This indicates that the panel voltage is too high in combination with the desired battery voltage. | ||
- | Reduce | + | Applies to the MPPT RS, Inverter RS and Multi RS products. |
- | ==== Err 38, Err 39 - PV Input shutdown ==== | + | Please upgrade your firmware to at least v1.08 as the issues causing this error have been addressed. |
Line 149: | Line 179: | ||
Check the PV array cabling and panel isolation, the inverter restarts automatically once the issue is resolved. | Check the PV array cabling and panel isolation, the inverter restarts automatically once the issue is resolved. | ||
- | ==== Err 42 - Inverter shutdown (Ground Fault) ==== | + | ==== Err 42 - Inverter shutdown (PV isolation) ==== |
- | The ground leakage current exceeds the allowed 30mA limit. | + | The ground leakage current |
Check the PV array cabling and panel isolation. | Check the PV array cabling and panel isolation. | ||
- | This error will not auto-reset. | + | Check the installation and restart the unit using the power-switch. |
==== Err 43 - Inverter shutdown (Ground Fault) ==== | ==== Err 43 - Inverter shutdown (Ground Fault) ==== | ||
Line 180: | Line 210: | ||
The inverter will restart after 30 seconds. The inverter will not stay off after multiple retries. | The inverter will restart after 30 seconds. The inverter will not stay off after multiple retries. | ||
- | ==== Err 53, Err 54 - Inverter output voltage ==== | + | ==== Err 53 - Inverter output voltage ==== |
If the battery voltage is getting low and a large load is applied to the AC output the inverter is unable to maintain the proper output voltage. | If the battery voltage is getting low and a large load is applied to the AC output the inverter is unable to maintain the proper output voltage. | ||
Re-charge the battery or reduce the AC loads to continue operation. | Re-charge the battery or reduce the AC loads to continue operation. | ||
+ | If the error immediately pops up when switching on the inverter (without load) on a full battery the cause is most likely a broken internal fuse. | ||
==== Err 55, Err 56, Err 58 - Inverter self test failed ==== | ==== Err 55, Err 56, Err 58 - Inverter self test failed ==== | ||
The inverter performs diagnostic tests before it activates its output. In the case that one of these tests fails an error message is displayed and the inverter does not turn on. | The inverter performs diagnostic tests before it activates its output. In the case that one of these tests fails an error message is displayed and the inverter does not turn on. | ||
Line 194: | Line 229: | ||
This error will not auto-reset. Check the installation and restart the unit using the power-switch. | This error will not auto-reset. Check the installation and restart the unit using the power-switch. | ||
Line 201: | Line 240: | ||
- | This Error only shows when there is solar power available and thus the Solarcharger | + | This error shows when the charger |
- | Check the connection between the charger and the BMS. | + | Solar Chargers only show this error when there is solar power available and thus the device is ready to initiate charging. It does not show at night. And in case there is a permanent problem, the error will raise in the morning and clear at night, and so forth. |
+ | Solution: check the connection between the charger and the BMS. | ||
__How to reconfigure the charger to standalone mode__ | __How to reconfigure the charger to standalone mode__ | ||
- | Our Chargers and Solarchargers | + | Our Chargers and Solar Chargers |
- | Here is what needs to be done to make the charger | + | When removing |
- | * VE.Can solar chargers, | + | * Chargers with LCD display: |
- | * VE.Direct solar chargers, reset the charger to factory defaults with VictronConnect, | + | * Other chargers: reset the charger to factory defaults with VictronConnect, |
Line 235: | Line 276: | ||
Now, if the same information is being received from two interfaces that have the same priority level (as VE.Can and VE.Direct), the charger does not know how to prioritize those, causing error 68 to be triggered. | Now, if the same information is being received from two interfaces that have the same priority level (as VE.Can and VE.Direct), the charger does not know how to prioritize those, causing error 68 to be triggered. | ||
Line 247: | Line 330: | ||
Line 264: | Line 357: | ||
If the error is only present in the history data and the unit operates normally this error can be ignored safely. Explanation: | If the error is only present in the history data and the unit operates normally this error can be ignored safely. Explanation: | ||
- | ==== Err 200, Err 201 - Internal DC voltage error ==== | + | ==== Err 200 - Internal DC voltage error ==== |
The unit performs internal diagnostics when activating its internal DC-DC converter. This error indicates that something is wrong with the DC-DC converter. | The unit performs internal diagnostics when activating its internal DC-DC converter. This error indicates that something is wrong with the DC-DC converter. | ||
This error will not auto-reset. Check the installation and restart the unit using the power-switch. If the error persists the unit is probably faulty. | This error will not auto-reset. Check the installation and restart the unit using the power-switch. If the error persists the unit is probably faulty. | ||
==== Err 203, Err 205, Err 212, Err 215 - Internal supply voltage error ==== | ==== Err 203, Err 205, Err 212, Err 215 - Internal supply voltage error ==== | ||
Line 273: | Line 382: | ||
- | ~~DISQUS~~ | ||
