mppt-error-codes
mppt-error-codes [2020-05-11 13:35] – [Err 68 - Network misconfigured] mvader | mppt-error-codes [2023-09-14 14:07] – rvanzundert | ||
+ | * Remote | ||
Line 27: | Line 40: | ||
Line 33: | Line 58: | ||
+ | Possible solutions | ||
Line 53: | Line 85: | ||
The feature of this safety protection is to detect a shorted cell; and stop charging. | The feature of this safety protection is to detect a shorted cell; and stop charging. | ||
==== Err 28 - Power stage issue ==== | ==== Err 28 - Power stage issue ==== | ||
Line 72: | Line 130: | ||
Note that this error was introduced in v1.36. So when doing an update, it might look like the firmware update caused this issue; but it doesn' | Note that this error was introduced in v1.36. So when doing an update, it might look like the firmware update caused this issue; but it doesn' | ||
+ | Possible causes: | ||
Line 77: | Line 143: | ||
Line 98: | Line 174: | ||
If the charger is unable to turn off the PV input, it will go into a safe mode in order to protect the battery from over-charging or having a high voltage on the battery terminals. In order to do that, the charger will stop charging and disconnect its own output. The charger will become faulty. | If the charger is unable to turn off the PV input, it will go into a safe mode in order to protect the battery from over-charging or having a high voltage on the battery terminals. In order to do that, the charger will stop charging and disconnect its own output. The charger will become faulty. | ||
+ | If the error immediately pops up when switching on the inverter (without load) on a full battery the cause is most likely a broken internal fuse. | ||
Line 105: | Line 240: | ||
- | This Error only shows when there is solar power available and thus the Solarcharger | + | This error shows when the charger |
- | Check the connection between the charger and the BMS. | + | Solar Chargers only show this error when there is solar power available and thus the device is ready to initiate charging. It does not show at night. And in case there is a permanent problem, the error will raise in the morning and clear at night, and so forth. |
+ | Solution: check the connection between the charger and the BMS. | ||
__How to reconfigure the charger to standalone mode__ | __How to reconfigure the charger to standalone mode__ | ||
- | Our Chargers and Solarchargers | + | Our Chargers and Solar Chargers |
- | Here is what needs to be done to make the charger | + | When removing |
- | * VE.Can solar chargers, | + | * Chargers with LCD display: |
- | * VE.Direct solar chargers, reset the charger to factory defaults with VictronConnect, | + | * Other chargers: reset the charger to factory defaults with VictronConnect, |
Line 139: | Line 276: | ||
Now, if the same information is being received from two interfaces that have the same priority level (as VE.Can and VE.Direct), the charger does not know how to prioritize those, causing error 68 to be triggered. | Now, if the same information is being received from two interfaces that have the same priority level (as VE.Can and VE.Direct), the charger does not know how to prioritize those, causing error 68 to be triggered. | ||
Line 151: | Line 330: | ||
Line 160: | Line 350: | ||
- | ~~DISQUS~~ | + | |
