mppt-error-codes
mppt-error-codes [2020-04-14 12:54] – [Err 68 - Network misconfigured] tabreu | mppt-error-codes [2023-07-19 08:54] – [Err 70 - Network misconfigured] rvanzundert | ||
+ | * Remote | ||
Line 27: | Line 40: | ||
Line 33: | Line 58: | ||
+ | Possible solutions | ||
Line 53: | Line 85: | ||
The feature of this safety protection is to detect a shorted cell; and stop charging. | The feature of this safety protection is to detect a shorted cell; and stop charging. | ||
==== Err 28 - Power stage issue ==== | ==== Err 28 - Power stage issue ==== | ||
Line 72: | Line 130: | ||
Note that this error was introduced in v1.36. So when doing an update, it might look like the firmware update caused this issue; but it doesn' | Note that this error was introduced in v1.36. So when doing an update, it might look like the firmware update caused this issue; but it doesn' | ||
+ | Possible causes: | ||
Line 77: | Line 143: | ||
Line 98: | Line 174: | ||
If the charger is unable to turn off the PV input, it will go into a safe mode in order to protect the battery from over-charging or having a high voltage on the battery terminals. In order to do that, the charger will stop charging and disconnect its own output. The charger will become faulty. | If the charger is unable to turn off the PV input, it will go into a safe mode in order to protect the battery from over-charging or having a high voltage on the battery terminals. In order to do that, the charger will stop charging and disconnect its own output. The charger will become faulty. | ||
+ | If the error immediately pops up when switching on the inverter (without load) on a full battery the cause is most likely a broken internal fuse. | ||
Line 105: | Line 236: | ||
- | This Error only shows when there is solar power available and thus the Solarcharger | + | This error shows when the charger is configured to be controlled by a BMS, but does not receive any BMS control messages. In that situation, the charger stops charging by reducing its output voltage to the battery base voltage (12V/ |
+ | Solar Chargers only show this error when there is solar power available and thus the device | ||
- | Check the connection between the charger and the BMS. | + | Solution: check the connection between the charger and the BMS. |
__How to reconfigure the charger to standalone mode__ | __How to reconfigure the charger to standalone mode__ | ||
- | Our Chargers and Solarchargers | + | Our Chargers and Solar Chargers |
- | Here is what needs to be done to make the charger | + | When removing |
- | * VE.Can solar chargers, | + | * Chargers with LCD display: |
- | * VE.Direct solar chargers, reset the charger to factory defaults with VictronConnect, | + | * Other chargers: reset the charger to factory defaults with VictronConnect, |
Applies to SmartSolar/ | Applies to SmartSolar/ | ||
- | The charger detects multiple conflicting network sources, with the same priority, trying to send the same information to the charger. VE.Can and VE.Direct interfaces have both the same priority level, and BLE (using VE.Smart Networking) has a lower priority. | + | To clear the error on the SmartSolar VE.Direct MPPTs update the FW version to v1.48 or higher. |
+ | __Background__ | ||
Having a higher priority level means that, if the same information (e.g. Battery voltage sense) is being received from both VE.Can and BLE (using VE.Smart Network) by the charger, the information on VE.Can will be used and the one coming from BLE will be ignored. | Having a higher priority level means that, if the same information (e.g. Battery voltage sense) is being received from both VE.Can and BLE (using VE.Smart Network) by the charger, the information on VE.Can will be used and the one coming from BLE will be ignored. | ||
- | Now, if the same information is being received from two interfaces that has the same priority level (as VE.Can and VE.Direct), the charger does not know how to prioritize those, | + | Now, if the same information is being received from two interfaces that have the same priority level (as VE.Can and VE.Direct), the charger does not know how to prioritize those, |
- | To clear the error on the SmartSolar/ | + | ==== Err 69 - Network misconfigured ==== |
- | Note: Connecting | + | Applies to Inverter RS and Multi RS models. Firmware versions 1.11 and higher. |
+ | This error indicates an issue in the configuration. There are units present | ||
- | To clear the error on the SmartSolar VE.Direct MPPTs update the FW version to v1.48 or higher. | ||
Line 148: | Line 326: | ||
Line 157: | Line 346: | ||
- | ~~DISQUS~~ | + | |
