mppt-error-codes
mppt-error-codes [2019-12-18 09:11] – tabreu | mppt-error-codes [2023-09-14 14:07] – rvanzundert | ||
+ | * Remote | ||
Line 27: | Line 40: | ||
Line 33: | Line 58: | ||
+ | Possible solutions | ||
Line 53: | Line 85: | ||
The feature of this safety protection is to detect a shorted cell; and stop charging. | The feature of this safety protection is to detect a shorted cell; and stop charging. | ||
==== Err 28 - Power stage issue ==== | ==== Err 28 - Power stage issue ==== | ||
Line 72: | Line 130: | ||
Note that this error was introduced in v1.36. So when doing an update, it might look like the firmware update caused this issue; but it doesn' | Note that this error was introduced in v1.36. So when doing an update, it might look like the firmware update caused this issue; but it doesn' | ||
+ | Possible causes: | ||
Line 77: | Line 143: | ||
Line 98: | Line 174: | ||
If the charger is unable to turn off the PV input, it will go into a safe mode in order to protect the battery from over-charging or having a high voltage on the battery terminals. In order to do that, the charger will stop charging and disconnect its own output. The charger will become faulty. | If the charger is unable to turn off the PV input, it will go into a safe mode in order to protect the battery from over-charging or having a high voltage on the battery terminals. In order to do that, the charger will stop charging and disconnect its own output. The charger will become faulty. | ||
+ | If the error immediately pops up when switching on the inverter (without load) on a full battery the cause is most likely a broken internal fuse. | ||
Line 105: | Line 240: | ||
+ | __Background__ | ||
- | The charger detects multiple conflicting network sources trying | + | The inverters remain operational, |
- | Applies to SmartSolar MPPTs and SmartSolar MPPTs VE.Can. | + | ==== Err 73 - Multiple AC inputs ==== |
- | The typical reason for the error to show is that the charger | + | Per phase only one active connection |
- | Resolution: disable the parallel operation by connecting VictronConnect, going to settings, then "VE.Smart networking" | + | The inverters remain operational, they won't connect |
- | For SmartSolar MPPT VE.Can only, also make sure its not connected | + | ==== Err 74 - Phase overload ==== |
+ | Applies | ||
- | Once the conflict is resolved | + | The number of inverters in parallel doesn' |
Line 149: | Line 330: | ||
Line 158: | Line 350: | ||
- | ~~DISQUS~~ | + | |
