mppt-error-codes
mppt-error-codes [2019-11-30 10:10] – [Err 119 - Settings data lost] boekel | mppt-error-codes [2020-05-06 10:43] – [Err 68 - Network misconfigured] tabreu | ||
Line 8: | Line 8: | ||
Line 90: | Line 91: | ||
* Error 38: First disconnect the solar panels and disconnect the battery. Wait for 3 minutes, then reconnect the battery first and next the panels. | * Error 38: First disconnect the solar panels and disconnect the battery. Wait for 3 minutes, then reconnect the battery first and next the panels. | ||
- | * Error 39: The charger will automatically resume operation once the battery voltage drops below the float level for 1 minute. | + | * Error 39: The charger will automatically resume operation once the battery voltage drops below its maximum voltage setting (normally Equalisation or Absorption voltages), for 250V versions or float voltage |
Line 105: | Line 110: | ||
The charger is configured to be controlled by a BMS, but it does not receive any control messages from a BMS. The charger stopped charging, as a safety precaution. | The charger is configured to be controlled by a BMS, but it does not receive any control messages from a BMS. The charger stopped charging, as a safety precaution. | ||
+ | This Error only shows when there is solar power available and thus the Solarcharger is ready to initiate charging. It does not show at night. And in case there is a permanent problem, the error will raise in the morning and clear at night, and so forth. | ||
Check the connection between the charger and the BMS. | Check the connection between the charger and the BMS. | ||
- | __How to reset the charger, to de-couple it from the BMS__ | + | __How to reconfigure |
- | When the charger needs to operate in stand-alone mode again, not controlled by a BMS, it needs to be reset: | + | Our Chargers and Solarchargers automatically configure themselves to be BMS-controlled when they are connected to one; either direct or via a GX Device. And that setting is semi-permanent: |
+ | Here is what needs to be done to make the charger | ||
* VE.Can solar chargers, go into the setup menu, and change setting ‘BMS’ from ‘Y’ to ‘N’ (setup item 31). | * VE.Can solar chargers, go into the setup menu, and change setting ‘BMS’ from ‘Y’ to ‘N’ (setup item 31). | ||
* VE.Direct solar chargers, reset the charger to factory defaults with VictronConnect, | * VE.Direct solar chargers, reset the charger to factory defaults with VictronConnect, | ||
- | Note that (solar-)chargers automatically configure themselves to be BMS-controlled when they are connected to one; either direct or via a Color Control GX or Venus GX. | ||
- | The charger detects multiple conflicting network sources trying to take control of the charger. | + | To clear the error on the SmartSolar VE.Direct MPPTs update |
- | Applies to SmartSolar | + | |
- | The typical reason for the error to show is that the charger is configured to operate in parallel using our [[https:// | + | |
- | Resolution: disable | + | To clear the error on the SmartSolar/ |
+ | Note: Connecting a Solar charger on both VE.Can and VE.Direct is not supported. | ||
- | For SmartSolar MPPT VE.Can only, also make sure its not connected | + | The error occur when the charger detects multiple conflicting network sources, with the same priority, trying |
- | Once the conflict | + | Having a higher priority level means that, if the same information (e.g. Battery voltage sense) |
+ | Now, if the same information is being received from two interfaces that has the same priority level (as VE.Can and VE.Direct), the charger does not know how to prioritize those, so then error 68 will be triggered. | ||
