mppt-error-codes
mppt-error-codes [2019-11-30 10:10] – [Err 119 - Settings data lost] boekel | mppt-error-codes [2019-12-18 09:11] – tabreu | ||
Line 8: | Line 8: | ||
Line 90: | Line 91: | ||
* Error 38: First disconnect the solar panels and disconnect the battery. Wait for 3 minutes, then reconnect the battery first and next the panels. | * Error 38: First disconnect the solar panels and disconnect the battery. Wait for 3 minutes, then reconnect the battery first and next the panels. | ||
- | * Error 39: The charger will automatically resume operation once the battery voltage drops below the float level for 1 minute. | + | * Error 39: The charger will automatically resume operation once the battery voltage drops below its maximum voltage setting (normally Equalisation or Absorption voltages), for 250V versions or float voltage |
==== Information 65 - Communication warning ==== | ==== Information 65 - Communication warning ==== |
