mppt-error-codes
mppt-error-codes [2019-08-07 10:08] – [Err 28 - Power stage issue] mvader | mppt-error-codes [2020-07-12 10:50] – [Err 119 - Settings data lost] mvader | ||
Line 8: | Line 8: | ||
Line 90: | Line 91: | ||
* Error 38: First disconnect the solar panels and disconnect the battery. Wait for 3 minutes, then reconnect the battery first and next the panels. | * Error 38: First disconnect the solar panels and disconnect the battery. Wait for 3 minutes, then reconnect the battery first and next the panels. | ||
- | * Error 39: The charger will automatically resume operation once the battery voltage drops below the float level for 1 minute. | + | * Error 39: The charger will automatically resume operation once the battery voltage drops below its maximum voltage setting (normally Equalisation or Absorption voltages), for 250V versions or float voltage |
Line 105: | Line 110: | ||
The charger is configured to be controlled by a BMS, but it does not receive any control messages from a BMS. The charger stopped charging, as a safety precaution. | The charger is configured to be controlled by a BMS, but it does not receive any control messages from a BMS. The charger stopped charging, as a safety precaution. | ||
+ | This Error only shows when there is solar power available and thus the Solarcharger is ready to initiate charging. It does not show at night. And in case there is a permanent problem, the error will raise in the morning and clear at night, and so forth. | ||
Check the connection between the charger and the BMS. | Check the connection between the charger and the BMS. | ||
- | __How to reset the charger, to de-couple it from the BMS__ | + | __How to reconfigure |
- | When the charger needs to operate in stand-alone mode again, not controlled by a BMS, it needs to be reset: | + | Our Chargers and Solarchargers automatically configure themselves to be BMS-controlled when they are connected to one; either direct or via a GX Device. And that setting is semi-permanent: |
+ | Here is what needs to be done to make the charger | ||
* VE.Can solar chargers, go into the setup menu, and change setting ‘BMS’ from ‘Y’ to ‘N’ (setup item 31). | * VE.Can solar chargers, go into the setup menu, and change setting ‘BMS’ from ‘Y’ to ‘N’ (setup item 31). | ||
* VE.Direct solar chargers, reset the charger to factory defaults with VictronConnect, | * VE.Direct solar chargers, reset the charger to factory defaults with VictronConnect, | ||
- | Note that (solar-)chargers automatically configure themselves to be BMS-controlled when they are connected to one; either direct or via a Color Control GX or Venus GX. | ||
- | The charger detects multiple conflicting network sources trying to take control of the charger. | + | To clear the error on the SmartSolar VE.Direct MPPTs update the FW version |
- | Applies | + | |
- | The typical reason for the error to show is that the charger is configured to operate in parallel using our [[https:// | + | To clear the error on the SmartSolar/BlueSolar MPPTs VE.Can, update |
- | Resolution: disable the parallel operation by connecting VictronConnect, | + | __Background__ |
- | For SmartSolar MPPT VE.Can only, also make sure its not connected | + | Error 68 indicates that the charger detects multiple conflicting network sources, with the same priority, trying |
- | Once the conflict | + | Having a higher priority level means that, if the same information (e.g. Battery voltage sense) |
Line 148: | Line 155: | ||
