mppt-error-codes
mppt-error-codes [2019-05-06 13:58] – [Err 68 - Network misconfigured] mvader | mppt-error-codes [2019-07-05 06:43] – [Err 20 - Maximum Bulk-time exceeded] mvader | ||
Line 37: | Line 37: | ||
+ | === AC Chargers === | ||
Line 137: | Line 141: | ||
If the error is only present in the history data and the unit operates normally this error can be ignored safely. Explanation: | If the error is only present in the history data and the unit operates normally this error can be ignored safely. Explanation: | ||
The charger cannot read its configuration, | The charger cannot read its configuration, |
