mppt-error-codes
mppt-error-codes [2019-05-06 13:46] – rvanzundert | mppt-error-codes [2019-08-07 10:08] – [Err 28 - Power stage issue] mvader | ||
Line 37: | Line 37: | ||
+ | === AC Chargers === | ||
Line 64: | Line 68: | ||
Disconnect all wires, and then reconnect all wires. If the error persists the charge controller is probably faulty. | Disconnect all wires, and then reconnect all wires. If the error persists the charge controller is probably faulty. | ||
Line 115: | Line 121: | ||
The charger detects multiple conflicting network sources trying to take control of the charger. | The charger detects multiple conflicting network sources trying to take control of the charger. | ||
- | All Smart Solar charger models: | + | Applies to SmartSolar MPPTs and SmartSolar MPPTs VE.Can. |
- | * If the charger | + | The typical reason for the error to show is that the charger |
- | VE.CAN Smart Solar chargers only: | + | Resolution: disable the parallel operation by connecting VictronConnect, |
- | * If the charger is connected via VE.CAN to a Venus GX device do not install a VE.Direct | + | For SmartSolar MPPT VE.Can only, also make sure its not connected |
Once the conflict is resolved the error will disappear and the charger will resume normal operation, usually within a minute. | Once the conflict is resolved the error will disappear and the charger will resume normal operation, usually within a minute. | ||
Line 137: | Line 143: | ||
If the error is only present in the history data and the unit operates normally this error can be ignored safely. Explanation: | If the error is only present in the history data and the unit operates normally this error can be ignored safely. Explanation: | ||
The charger cannot read its configuration, | The charger cannot read its configuration, |
