mppt-error-codes
mppt-error-codes [2019-01-22 10:16] – external edit 127.0.0.1 | mppt-error-codes [2023-09-14 14:07] – rvanzundert | ||
+ | * Remote | ||
Line 26: | Line 40: | ||
Line 32: | Line 58: | ||
- | A cause for this error can be switching on a very large load on the battery side. | + | |
+ | Possible solutions | ||
+ | === AC Chargers === | ||
==== Err 28 - Power stage issue ==== | ==== Err 28 - Power stage issue ==== | ||
Line 65: | Line 128: | ||
Disconnect all wires, and then reconnect all wires. If the error persists the charge controller is probably faulty. | Disconnect all wires, and then reconnect all wires. If the error persists the charge controller is probably faulty. | ||
+ | Possible causes: | ||
Line 70: | Line 143: | ||
- | * Error 39: The charger will automatically resume operation once the battery voltage drops below the float level for 1 minute. | + | * Error 39: The charger will automatically resume operation once the battery voltage drops below its maximum voltage setting (normally Equalisation or Absorption voltages). It can also takes a minute |
+ | If the error immediately pops up when switching on the inverter (without load) on a full battery the cause is most likely a broken internal fuse. | ||
Line 94: | Line 240: | ||
+ | __Background__ | ||
Line 121: | Line 329: | ||
If the error is only present in the history data and the unit operates normally this error can be ignored safely. Explanation: | If the error is only present in the history data and the unit operates normally this error can be ignored safely. Explanation: | ||
Line 126: | Line 345: | ||
- | ~~DISQUS~~ | + | |
