mppt-error-codes
mppt-error-codes [2018-06-28 11:38] – [Err 18 - Controller over-current] rvanzundert | mppt-error-codes [2023-07-19 08:54] – [Err 70 - Network misconfigured] rvanzundert | ||
+ | * Remote | ||
Line 26: | Line 40: | ||
Line 32: | Line 58: | ||
- | A cause for this error can be switching on a very large load on the battery side. | + | |
+ | Possible solutions | ||
+ | === AC Chargers === | ||
Line 59: | Line 116: | ||
+ | Possible causes: | ||
Line 64: | Line 143: | ||
- | * Error 39: The charger will automatically resume operation once the battery voltage drops below the float level for 1 minute. | + | * Error 39: The charger will automatically resume operation once the battery voltage drops below its maximum voltage setting (normally Equalisation or Absorption voltages). It can also takes a minute |
+ | If the error immediately pops up when switching on the inverter (without load) on a full battery the cause is most likely a broken internal fuse. | ||
Line 88: | Line 236: | ||
+ | __Background__ | ||
Line 115: | Line 325: | ||
If the error is only present in the history data and the unit operates normally this error can be ignored safely. Explanation: | If the error is only present in the history data and the unit operates normally this error can be ignored safely. Explanation: | ||
Line 120: | Line 341: | ||
