mppt-error-codes
mppt-error-codes [2018-04-19 11:18] – [Err 38 - Input shutdown due to battery over-voltage] mvader | mppt-error-codes [2018-07-24 16:17] – rvanzundert | ||
Line 33: | Line 33: | ||
- | Disconnect | + | If the error does not auto-reset disconnect |
- | If the error persists the charge controller is probably faulty. | + | A cause for this error can be switching on a very large load on the battery side. |
Line 58: | Line 58: | ||
Line 67: | Line 73: | ||
- | ==== Err 38 - Input shutdown | + | ==== Err 38, Err 39 - PV Input shutdown ==== |
- | To protect the battery from over-charging the panel input is shorted. To recover from this condition first disconnect the solar panels and disconnect the battery. Wait for 3 minutes, then reconnect the battery first and next the panels. | + | To protect the battery from over-charging the panel input is shorted. |
- | A common reason | + | Possible reasons |
- | Another reason is that there is another device connected to the battery, which is configured to a higher voltage. For example a MultiPlus, configured to equalise at 17 Volts, while in the MPPT | + | Error recovery: |
+ | * Error 38: First disconnect the solar panels and disconnect | ||
Line 105: | Line 117: | ||
- | The unit is faulty, contact your dealer for a replacement. | + | If the unit does not work and error 116 pops up as the active error the unit is faulty, contact your dealer for a replacement. |
==== Err 119 - Settings data lost ==== | ==== Err 119 - Settings data lost ==== |
