mppt-error-codes
mppt-error-codes [2017-08-12 08:07] – [MPPT Solar Charger Error Codes] mvader | mppt-error-codes [2024-02-12 05:48] (current) – [Err 54 - Inverter output voltage] guy_stewart | ||
+ | * Remote | ||
Line 26: | Line 40: | ||
Line 32: | Line 58: | ||
- | Disconnect | + | |
- | If the error persists the charge controller is probably faulty. | + | |
+ | Possible solutions | ||
+ | === AC Chargers === | ||
Line 59: | Line 116: | ||
+ | Possible causes: | ||
Line 64: | Line 143: | ||
- | ==== Err 38 - Input shutdown due to battery | + | ==== Err 35 - PV over-power ==== |
- | To protect the battery from over-charging the panel input is shut down. To recover from this condition first disconnect the solar panels and disconnect the battery. Wait for 3 minutes reconnect the battery first and next the panels. | + | |
- | A common reason for this error to occur is that the Battery voltage (12/24/48V) is set, or auto-detected, | + | Applies |
- | Use VictronConnect | + | Please upgrade your firmware |
+ | * There is another device connected to the battery, which is configured | ||
+ | Error recovery: | ||
Line 82: | Line 240: | ||
- | ==== Err 114 - CPU temperature | + | When removing charger from such system, and reusing it in a system without BMS, that setting needs to be cleared. |
+ | __Background__ | ||
Line 105: | Line 325: | ||
- | The unit is faulty, contact your dealer for a replacement. | + | If the unit does not work and error 116 pops up as the active error the unit is faulty, contact your dealer for a replacement. |
Line 111: | Line 345: | ||
