mppt-error-codes
mppt-error-codes [2017-08-12 08:07] – [MPPT Solar Charger Error Codes] mvader | mppt-error-codes [2019-05-06 13:58] – [Err 68 - Network misconfigured] mvader | ||
Line 33: | Line 33: | ||
- | Disconnect | + | If the error does not auto-reset disconnect |
- | If the error persists the charge controller is probably faulty. | + | A cause for this error can be switching on a very large load on the battery side. |
Line 58: | Line 58: | ||
Line 65: | Line 71: | ||
The current from the solar-panel array has exceeded 75A. This error could be generated due to an internal system fault. | The current from the solar-panel array has exceeded 75A. This error could be generated due to an internal system fault. | ||
- | ==== Err 38 - Input shutdown | + | ==== Err 38, Err 39 - PV Input shutdown ==== |
- | To protect the battery from over-charging the panel input is shut down. To recover from this condition first disconnect the solar panels and disconnect the battery. Wait for 3 minutes reconnect the battery first and next the panels. | + | To protect the battery from over-charging the panel input is shorted. |
- | A common reason | + | Possible reasons |
- | Use VictronConnect to disable auto-detect | + | Error recovery: |
+ | * Error 38: First disconnect the solar panels | ||
+ | * Error 39: The charger will automatically resume operation once the battery | ||
Line 99: | Line 111: | ||
Note that (solar-)chargers automatically configure themselves to be BMS-controlled when they are connected to one; either direct or via a Color Control GX or Venus GX. | Note that (solar-)chargers automatically configure themselves to be BMS-controlled when they are connected to one; either direct or via a Color Control GX or Venus GX. | ||
- | ==== Err 114 - CPU temperature | + | ==== Err 68 - Network misconfigured ==== |
+ | The charger detects multiple conflicting network sources trying to take control of the charger. | ||
+ | Applies to SmartSolar MPPTs and SmartSolar MPPTs VE.Can. | ||
+ | The typical reason for the error to show is that the charger is configured to operate in parallel using our [[https:// | ||
+ | Resolution: disable the parallel operation by connecting VictronConnect, | ||
+ | For SmartSolar MPPT VE.Can only, also make sure its not connected to a [[https:// | ||
+ | Once the conflict is resolved the error will disappear and the charger will resume normal operation, usually within a minute. | ||
Line 105: | Line 133: | ||
- | The unit is faulty, contact your dealer for a replacement. | + | If the unit does not work and error 116 pops up as the active error the unit is faulty, contact your dealer for a replacement. |
Line 115: | Line 146: | ||
